Are there thin sheets of material on the market that have resistance levels - comparable to resistors, which vary in a well defined relation to units of distance?
Well hell, that makes sence. Never thunked of that
__________________ Pay it forward. Last edited by Mikebits; 31st October 2008 at 05:12 AM. | |
Black anti-static polythene bags.
Could you help me find some "telo deltos" paper? I tried to find an internet translation - and did an internet search, and couldn’t find any. I’ve used carbon paper before and never thought of its electrical properties. However, the carbon paper would be exposed to rubbing and I’m afraid that this might change the carbon paper's electrical properties. The black anti-static polythene bags might work, but something more rigid would be better. Something transparent would be the best.
| | #6 | |
BDM (Braddock, Dunn & McDonald) corp. knew where to get this paper, and the correct spelling. With computers this kind of thing is probably obsolete unless it has other uses. I hope this helps. | ||
| | #7 | |
| | #8 |
Can anyone help me out with some engineering terms that might help me search the internet for rigid sheets – preferably transparent, or paint that has a well defined rate of resistance per unit distance?
| | #9 | |
sheet resistivity sheet conductivity carbon conductive coating resistive coating flexible silvery | ||
| | #10 | |
At one time, I had experimented with this but, the results weren't great. I didn't really try to refine the technique. | ||
| | #11 |
Hi there, Just to note, i tried some "Wire Glue" a while back and although it was pretty neat stuff it did not have a well defined resistance as i think you are looking for. It was resistive alright, but it varied quite a bit with temperature and bending of the base insulator and stuff like that. Perhaps you can tell us what you are trying to do or build or whatever so that we might know of something else that would work... | |
| | #12 |
Still hung up on that game board idea are we? Structure of resistor question What is it about conductors that gives them resistive properties? Are you just going to keep asking the same question over and over until someone tells you what you want to hear? Normally, when people run into problems like this in a project it's one of two things: -It's impossible with current technology -They are going about it the wrong way There was oodles of respones with very in-depth discussion about why your implementation would not work the last few times you asked this question, as well as many alternatives. To summarize what he is asking for people who aren't up to speed: He wants a resistive playing board with multiple conductive/resistive playing pieces. Placing the playing pieces on the board is supposed to change the resistance in that particular area of the board, and thus change the resistance seen by 3 contacts connected to the edges of the board. By measuring the change in resistance (or current flow) between these 3 contacts, he wants to monitor the position of all playing pieces on the board. Furthermore, he wants it to be transparent so he can overlay a "graphical map" of sorts onto the board.
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 25th May 2009 at 07:28 AM. | |
| | #13 | |
| | #14 | |
| | #15 | |
| resists, sheet |
| data sheet | avinaik | Datasheet/Parts Requests | 4 | 29th March 2007 04:06 AM |
| old ic data sheet | paul(nc) | Datasheet/Parts Requests | 3 | 15th December 2006 06:03 AM |
| ic data sheet | fundusam | Datasheet/Parts Requests | 3 | 7th October 2005 12:58 AM |
| LCD data sheet | andrew2022 | Datasheet/Parts Requests | 0 | 24th August 2004 10:56 PM |
| need data sheet on.. | Bruce L Williamas | Datasheet/Parts Requests | 2 | 4th October 2003 07:18 AM |
