She 'tis not there.
Sheet resistance is no different to the resistivity of a cable, just replace the cross-sectional area with W×t, where W is the width and t is the thickness.
Please attempt the following problems:
I have a sheet 2mm thick, 50mm wide and 2m long and is made of a material with a resistivity of 2.5mΩ·m, what's the resistance of the sheet?
I need a sheet 5mm thick, 100mm wide and 0.5m long with a resistance of 1k, what resistivity material do I need?
Note you'll need to convert all the prefixes to base units: i.e. replace mΩ with 0.001Ω, and mm with 0.001m before doing any calculations otherwise you'll go wrong.
Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer.
Actually, that wont help too much. What he needs to convert is his mind away from his childish, pointless game. There's probably not much point in suggesting that he try to convert it to anything involving electronics or technology since it's obvious that the only interest he has in any of that is in how to use it to continue his ploy.
I admit it. I was wrong. I thought he'd pretty well exhausted the range of piddly, pointless ploys to keep his game alive. But, this one was his next move. We should learn from it.
Of course, he's not going to let on that he's trying to actually understand anything but, he's now going out and doing searches on the internet to come up with some semi_related, esoteric crap that he can pretend that he needs assistance with. Ohm's Law is too "useful" so, he throws out some formulas he found on Wiki as his way to cry out for his next his next round of attention.
Okay, you gave hime a simple problem and some prompts. Let's see if he manages to actually come up with the correct answer (BTW: that grinding noise you are hearing is the rusty wheels turning in his head as he figures out how to make sure that the correct answer is the last thing he will come up with).
He has vectored around my predictions in the past but, I don't think he can vector around this one (at least not by doing what he knows is the right thing) without tipping his hand.
As I said, watch and learn, boys and girls.
The formulas that I am - to use your word, throwing out, are ones that relate resistance to distance. I am not sure what these forumlas define because I don't know how L is described. I have not given up on Ohm's law. I am only looking for a way to describe resistance as a function of distance - whether this involves combining Ohm's law with another equation or not. Notwithstanding your statement, I think that this involves electronics.
She 'tis not there.
It would be helpful if someone would tell me if L in R = pL/A = pL/(Wt) - at Sheet resistance - Wikipedia, the free encyclopedia, means length of the sheet, the length between arbitrarily located point electrical contacts on the sheet, and/or the length between a different type of electrical connection resulting in a uniform current through a line defining a side of the sheet - and perhaps a uniform current through the opposite side as well.
She 'tis not there.
It's the formula to estimate the resistance form one end of a sheet to the other.
Read the Wikipedia artical, it should be fairly obvious.I don't know what L means.
I will not try to help you any more unless you answer the problems I set you in my previous post.It would be helpful if someone would tell me if L in R = pL/A = pL/(Wt) - at Sheet resistance - Wikipedia, the free encyclopedia, means length of the sheet, the length between arbitrarily located point electrical contacts on the sheet, and/or the length between a different type of electrical connection resulting in a uniform current through a line defining a side of the sheet - and perhaps a uniform current through the opposite side as well.
It is obvious to me that L has something to do with the length of the sheet. It is not obvious to me if the formula is independent of the location of electrical contacts; if L means the distance between electrical contacts; if L does mean the distance between electrical contacts - if the electrical contacts as implied by the formula have to be point contacts, or if the electrical contacts have to be such that there is one or two uniform currents through lines defining opposite sides of the sheet.
She 'tis not there.
I'm trying to figure out if a formula - Rs = (V/I) * CF - at Sheet Resistance might apply. Does anyone know another name for CF that I can use in a search?
She 'tis not there.
You have to learn to walk before you can learn to run. I would suggest that we withhold all technical assistance from this guy until he shows that he has at least taken the effort to learn and be able to apply, Ohm's Law.
I love the idea of putting the ball in his court and watching him squirm as he conives ways to try to continue groveling for attention without actually showing any cognizance.
It surely shouldn't be too difficult for a guy who is asking for detailed technical information on advanced levels to be able to show compentency in something taught in the first week on any high school level electronics class.
Okay, okay...I thought I could do it and, bleieve me I wrestled with my demons (and lost) so...
Perhaps an appropriate search for CF for you might be, "c**t face"?
I think hes doing rather well being you keep giving him the attention! Direct attention or not, he is still hanging in there thanks to you!I love the idea of putting the ball in his court and watching him squirm as he conives ways to try to continue groveling for attention without actually showing any cognizance.
Crashsite 0
Jasonbe 1
I am almost half tempted to give jasonbe positive rep points just for playing you guys so very well!
As inept as he may look at electronics and electrical theory he obviously knows how to play this game and he is playing it very very well!![]()
"When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
Crashsite in the post that I am responding to compares learning Ohm's law,
V = IR, with learning how to walk. I don't want to write anything that would discourage people from participating in this site because of math. However - while the math for this formula might not seem to be the most advanced, the molecular activity associated with it seems to me as though it could be studied in depth. How much crashsite believes that a person should know about molecular activity associated with this formula before participating in this site, I do not know. Perhaps there are simplified ways of describing the basics of molecular activity that relate to Ohm's law and maybe even describe it partially or in full. I can't say that I understand the basics at this time - and I don't know if they are known by anyone at this time.
The formula can be rewritten as R = V/I. The term that I meant to express interest in is a constant multplied by V/I. Putting the chemical significance of the term aside - which might be considered acceptable to do if crashsite is accurate in saying that Ohm's law might be taught in the first week of a high school course, mathematically, V/I does not seem too much more difficult to calculate than a constant multiplied by V/I. In this case, the constant is CF - which I think is the resistance correction factor, and the overall equation is (V/I)*CF.
I would be interested in knowing for what reason crashsite thinks that it is acceptable to learn R = V/I and not V/I multiplied by CF. I would like to know if anything besides perjorative language supports crashsite in this instance.
She 'tis not there.
This may be risky, but I am tempted to ask you, as long as you are playing along - why is it likely that the sites that I have found describe the resistance correction factor - if that is in fact what CF stands for, as a function of only temperature and not probe spacing.
She 'tis not there.
