| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
Hi All, I am trying to cacalculate the strength of electromagnets. After some searching i have found the equations but i just can't quite get a handle on some of it? They have an iron core C shaped electromagnet 15cm long & 1cm square in area with a 1cm air gap & the permeability of air is 1 in this example. They write: The reluctance of the air gap is 1 centimeter divided by 1 times 1 square centimeter. The answer they have is 100 henries per meter. (1 centimeter) / (1 * 1 (square centimeter)) = 100 m-1 How do they calculate this to get 100 as the answer? I noticed that Reluctance is in Henries per Meter but the above calculation is in Centimeters so i assume the answers i have been getting are actually Henries per Centimeter, do i simply multiply the answer by 100 to change it to meters & then the answer is in Henries per meter & seem correct?. Any help will be greatly appreciated | |
| | #3 | |
Dimensional analysis - Wikipedia, the free encyclopedia | ||
Normally we would calculate reluctance R like this: R=L/(u0*ur*A) where R is reluctance (1/h) L is length (m) u0 is magnetic space constant (h/m) ur is relative permeability A is area (m*m) and we would get 79577471.5 (1/h), but apparently here they want to use instead: R=L/(ur*A) with same definitions as above except R has different dimension. Proceeding with the calculation, we'll first convert to meters and sq. meters: L=0.01 meters A=0.0001 square meters Using the formula now, R=0.01/(1*0.0001)=100 in units of 1/m which might be called h/m. To use this we'd have to include the u0 constant: R=100/(4*pi*10^-7)=79577471.5 in units of (1/h) Last edited by MrAl; 16th October 2008 at 02:11 PM. | |
Thank you MrAl & all for there comments. Your help is greatly appreciated. Thanks Again | |
| math |
| Math | hjl4 | General Electronics Chat | 8 | 30th August 2007 12:46 AM |
| Math help? | Mike, K8LH | Micro Controllers | 10 | 9th April 2007 11:07 PM |
| math help | shermaine | Math and Physics | 12 | 27th November 2006 11:40 AM |
| Math Help | shermaine | General Electronics Chat | 9 | 21st April 2004 02:39 PM |
| Need Help In Math | shermaine | General Electronics Chat | 6 | 8th March 2004 02:46 PM |
