Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 27th March 2008, 12:29 AM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Default Divide by 6 using C and avoiding floating point?
I'm doing a dice program using a freerunning timer that automatically and fairly counts from 0-6^x (where x is number of die)
Now one die is easy (I'm a BASIC programmer but want to do it in C18)
So
A single die is roll+1
Two dice are D1=int(roll/6)+1 and D2=(roll mod 6)+1
Any ideas on 3 or more dice? And avoiding floating point...
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 27th March 2008, 01:25 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Isn't it just
D1=roll mod 6
D2=(roll/6) mod 6
D3=(roll/36) mod 6
D4=(roll/216) mod 6
etc.
If you do it in integer maths then it should just work.
Pommie is offline   Reply With Quote
Old 27th March 2008, 03:20 AM   (permalink)
Experienced Member
There you go, thanks I just couldn't see the forest for the trees.
Bill
Old 27th March 2008, 11:44 AM   (permalink)
Experienced Member
Does the MCU you're using have a hardware divide instruction or are you useing a maths library?
The x86 does and puts the quotent and remainder in to different registers. Using a high level language like C will probably end up producing two divide instructions, one to get the remainder and another for the quotent which is a wate of clock cycles. I'd recommend doing the division part in assembler, that way you can use one instruction to get both the quotent and remainder.
Old 27th March 2008, 02:11 PM   (permalink)
Experienced Member
What use is the remainder? For D4 the calculation goes, int(roll/216), result/6 and keep remainder. Two divides required anyway. D2 is the only one that could benefit from the remainder but the additional code wouldn't be worth it.
Old 27th March 2008, 04:52 PM   (permalink)
Experienced Member
I don't see why more than one divider per iteration is required.
Roll is the variable with the the value generated by the timer.
Divide, is the divide instruction, it accepts two variables, the first value is divided by the second value. After the instruction is executed the quotent is stored in the first variable and the remainder is stored in the second.
e.g.
x = 105
y = 10
Divide x, y
Print x, y
The output will be:
10 5
Assuming the PIC has a similar instruction, here's how you'd use it. Roll is the random number which is set before the code runs.
Do
Remainder = 6
Divide Roll, Remainder
Print Remainder
Loop until Roll = 0
Old 27th March 2008, 09:13 PM   (permalink)
Experienced Member
Well the formula should work well as an unsigned int function (now I'll have to learn C18 functions)
for Roll = 0 to 6^4-1
D1 = int(Roll/1 mod 6)+1
D2 = int(Roll/6 mod 6)+1
D3 = int(Roll/36 mod 6)+1
D4 = int(Roll/216 mod 6)+1
print Roll, D1, D2, D3, D4
next
Just BASIC program
Bill
Old 27th March 2008, 11:05 PM   (permalink)
Experienced Member
Hero,
I see what you mean now. Doing it in asm would save a divide.
Bill,
In C it would simply be,
    D2=((Roll/6)%6)+1;
Not much difference really.
Old 27th March 2008, 11:16 PM   (permalink)
Experienced Member
Thanks I always thought % meant binary. But in C it means modulo.
Using special mode the CCP allows TMR1 to be a free running modulo x counter.
Bill
Old 27th March 2008, 11:45 PM   (permalink)
3v0
Moderator
3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold
0xAA = 0b10101010
search engine for electronic parts
Junebug USB PIC programmer kit. USB Bit Wacker
3v0 is online now   Reply With Quote
Old 27th March 2008, 11:51 PM   (permalink)
Experienced Member
Ahh, the special event trigger, one of my favourites.
Old 28th March 2008, 01:37 AM   (permalink)
Experienced Member
It's a real gem, it was one of your older posts that pointed it out to me.
It occurred to me to let it free run till you press a button, presto instant random number.
I could do the software in Swordfish easy, but it's more a challenge to do it in C18.
Eventually I'll make a Risk game battle dice (5 dice) roller on the Junebug as one of the tutorials.
Bill
Old 8th April 2008, 06:25 AM   (permalink)
Experienced Member
petrv will become famous soon enough
You can of course use the compiler's runtime library to do the division if the PIC does not have a hardware divider, but if it is just for 2 dice why don't you use repeated substraction in a loop ? Stupid ,yes but very simple and performance is not a concern in this case, anyway the number of iterations would be 0 to 5 so who cares ? This will give you both the result of the division and the remainder... easy to do even in assembly.
Petr
petrv is offline   Reply With Quote
