| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
| New Member | let me give my requirement in detailed way.... Actually I want a algoritham to compress 12 digit hexa value into less than 9 digit decimal value. example : this hexa value "000A3A7C0ED0" should be compressed into less than 9 digit decimal value like "234876123" again if I uncompress decimal value it has to give same hexa value.... Thanks in advance |
| Experienced Member | Without suitable restrictions on the range of possible values there is no known algorithm that will provide a 1:1 map from 2^48 possibilities onto 2^36 code words. The mapping must be 1:1 because you need to have a unique inverse map.
__________________ We never have time to do it right; but we always have time to do it over. |
| Experienced Member | Quote:
You can't simply map a larger space to a smaller space like the post above this one pointed out, thats not how compression works. There would be no way of reversing the compression to get back your hex number, which is the problem. Last edited by 3iMaJ; 14th March 2008 at 06:18 PM. | |
| Experienced Member | Change it to a higher base. Eg. Base 36, 0 > Z. It will take up less characters as the place value of each is 36 rather than 16. I hope you understand what I mean... lol.
__________________ What is a joule per second? |
| Experienced Member | Compression is based on the fact that data is repeated within your subset. For instance, in your example, you could take the original string and calculate the number of occurances of each: 000A3A7C0ED0 Code: 0->5 A->2 3->1 7->1 C->1 E->1 D->1 0 = 000 A = 001 3 = 010 7 = 011 C = 100 E = 101 D = 110 Now that we have a working dictionary, we can compress your data as follows: Code: 0 0 0 A 3 A 7 C 0 E D 0 000 000 000 001 010 001 011 100 000 101 110 000 00145C170 which is 3 characters shorter than the original. However, the usefullness of this is pretty much lost completely in this example because in order to revert back to the original, you need to send the dictionary as well, which in this case would significantly increase the size of what you need to send. You can also play with the size of each chunk of data as well, and you will get different compression ratios as a result. For instance, in your data we might make the chunk size only half of a nibble or we might make it a full byte. If you were to do it with half a nibble, your compression becomes: Code: uncompressed message (binary) = 00 00 00 00 00 00 10 10 00 11 10 10 01 11 11 00 00 00 11 10 11 01 00 00 dictionary: 00 -> 12 10 -> 5 11 -> 5 01 -> 2 If we make the chunk size a full Byte, your data is compressed like this: Code: 00 = 000 0A = 001 3A = 010 7C = 011 0E = 100 D0 = 101 compressed message= 0000 0001 0100 1110 0101 = 014E5 If you were sending a rather large file with lots of repeated data, you will save lots of space. For example, if the data you are sending is ASCII text, chances are that you are using a small subset of ASCII (ie the alphabet, and numbers, some symbols) substantially more often than some of the more rare characters and it would be advantageous to compress them in this fashion. If you knew you were sending the english language, for instance, you could analyze a large block of text (an ebook or something) and use the distribution of characters to build your dictionary. So, to answer your question, the only way you could effectively compress your data would be if you knew something about the distribution of data, and could either create a dictionary that is shared between the encoder/decoder or dynamically generated and transmitted alongside the data on the fly. I've written a nice compression utility in one of my university courses, but I dont remember the precise implementation, and I'm sure I've omitted some details in my brief description above. My implementation relied on building the dictionary with a Huffman tree which uses ordered insertion to create the dictionary, and then you get keys by traversing the tree. See wikipedia: http://en.wikipedia.org/wiki/Huffman_coding for more. |
| Atmel, assembly:displaying on lcd | Haidy | Micro Controllers | 13 | 11th February 2008 08:12 PM |
| 2 digit 7 segment display.. | overmind | Micro Controllers | 12 | 17th January 2008 03:34 AM |
| asm attachments | eng1 | Feedback/Comments | 6 | 14th September 2007 03:01 PM |
| multiplication of 1 digit BCD with 1 digit BCD | David84 | Electronic Projects Design/Ideas/Reviews | 3 | 18th October 2006 03:21 PM |
| Multiple digits 7 segments display | Joel Rainville | Micro Controllers | 44 | 22nd August 2005 08:21 PM |
