Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 14th March 2008, 12:54 AM   (permalink)
Experienced Member
SeanHatch is on a distinguished road
Send a message via AIM to SeanHatch
Default Do ears alias?
The eyes do, I know, but do the ears?
SeanHatch is offline   Reply With Quote
Old 14th March 2008, 01:12 AM   (permalink)
Experienced Member
bananasiong is a glorious beacon of lightbananasiong is a glorious beacon of lightbananasiong is a glorious beacon of lightbananasiong is a glorious beacon of light
I say no. Do ears do sampling?
Superman Returns..
http://www.supermanhomepage.com/imag...an-returns.gif
My friend created this account for me.. LOL
http://bananasiong.myminicity.com
oh.. somemore
http://bananasiong.myminicity.com/env
bananasiong is offline   Reply With Quote
Old 14th March 2008, 01:13 AM   (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
I don't think so because the ear is like a filter that is just unable to pass frequencies that are outside of it's bandwidth. Like 20-20kHz it can hear fine (right?) so no aliasing (I would assume). If I fed your ear 40kHz, sure it woudl alias...if your ear could detect it in the first place, which it can't.
Ears only work with things that "contain a single frequency characteristic" or a single "dimension" or 2D (as in they can be graphed properly in 2D, more accurately than light anyways). I'm not sure how to word it. Like eyes for example have the frequency of the light itself as well as the frequency that the light's magnitude is changing at (flashing for example). It might be flashing at 10Hz, but the frequency of the light might be 600THz. With ears you just have the frequency of the sound waves.
Old 14th March 2008, 01:16 AM   (permalink)
Experienced Member
3iMaJ has a spectacular aura about
The assumption here is that there is a sort of sampling going on. I doubt the ears sample, they act like a filter as stated earlier. If anything samples its likely the brain, but if there's a prefilter on what we're sampling then aliasing is unlikely to occur.
I don't understand the anatomy, so its just best guess. But for aliasing to occur there has to be sampling. I am curious, however, how the eyes alias. What is it they alias? What is their sampling rate, what do you define as aliasing?
Are they aliasing in spatial frequency? Are they aliasing spatial objects? Certainly they don't have very fine resolution otherwise they'd act like a microscope, but coarse resolution doesn't imply aliasing.
3iMaJ is offline   Reply With Quote
Old 14th March 2008, 01:21 AM   (permalink)
Experienced Member
Eyes don't really sample either. Your eyes don't really see discrete images. It's a strange realm of analog blurred discretely. Biology works in strange ways that aren't truly the words we use to describe them.
I was about to use this analogy to demonstrate that the eye doesn't really sample: shining alternating black and white into the eye and that if I synched it just right then your eye would only see one colour, either black or white (such that the other colour only appeared in between samples that the eye took). Well we know this isn't true (right?), but we also know that you'd always see white and not black if we flashed these colours because light overrides dark for the eye. If I flashed a lot of black and a little white, you'd still see the white. But if I flashed a lot of white and a little black, you wouldn't see the black. You will always see the white and not the black.
This point reminded me of this article I read a while ago which you might find interesting. But I think it still somewhat shows that the eyes doesn't really digitally sample.
http://www.100fps.com/how_many_frame...humans_see.htm
Old 14th March 2008, 01:31 AM   (permalink)
Experienced Member
I didn't think they sampled, which makes aliasing the way we understand it from DSP impossible. But I don't know much about anatomy so I wasn't sure.
Old 14th March 2008, 01:32 AM   (permalink)
Experienced Member
Plus there's also the problem of human perception which is hard to sift out to differentiate what the eye detects and what we see.
Old 16th March 2008, 11:47 PM   (permalink)
Experienced Member
The inner ear acts as a low pass filter, if it's bypassed and the sound is fed directly to the auditory nerve, sounds up to 200kHz can be detected - 10 times the bandwidth of a young ear!
The eyes are different, the frequency response, resolution and colour depth all depend on where the image is in the field of vision. There more cone cells in the middle of the retina so the colour depth and resolution is higher in the middle and there are virtually no cones and all rods as the edge of the retina so the colour perception and resolution are poor here. Rods have a faster response time than cones and this is why it's ofen possible to see monitors and fluroscent tubes flicker out of the corner of one's eye and which isn't possible whilest looking directly at them.
Old 17th March 2008, 09:07 PM   (permalink)
Experienced Member
Analog has a spectacular aura about
Photo detectors in the eye can actually detect single photons. However, the brain automatically filters that, so that at least 5 photons or thereabouts are needed to detect light. Otherwise, our eyesight would be a lot more noisy.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline   Reply With Quote
How I "Discovered" Logarithms crashsite Math and Physics 19 11th February 2008 02:09 AM
Ultrasonic ears AllanBertelsen Electronic Projects Design/Ideas/Reviews 12 25th April 2007 07:01 PM
Ultrasonic Ears George L. Electronic Projects Design/Ideas/Reviews 1 7th March 2007 11:52 PM
