Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 29th December 2007, 03:47 PM   (permalink)
Default Surface Integrals Concerning Flux
Hi Guys,
Name's Quixotron. I am writing to you to ask about a electromagnetics problem(well its a flux problem, but its in an EM book). I have already computed the answer and just want to double check my work, because the book gives another answer and books tend to have typos from time to time.
Ok.
The problem is to calculate the flux emanating from the exhaust of a jet engine.
The air gas velocity from a jet engine varies linearly from a maximum of 300 m/s at the center of the circular exhaust opening to zero at the edges. If the exhaust diameter is 1.6 m, find the exhaust flow.
Alright. My first assumption is that I cannot use the B*A cos (theta) dot product, because the flow rate B, is not uniform, it varies linearly.
1: Compute B
Since it varies linearly I can derive an equation that gives me the flow rate as a function of position.
Used y=mx +b
b=300 m/s at center
x =radius in meters = r
m=slope=0-300/(0.8-0)=-375 cycles/s, 0.8 is radius of circular opening
y=B=-(375*x)+300
m/s
2: Compute Flux, Psi
flux(non-uniform flux denisity) = Double integral B dot dS
dS = surface area of circle=pi*r^2 in this case.
limits are 0-0.8 of both integrands
variable of interest is r. similar to integrating acceleration twice to get position
3: Plug in and solve
pi* SS (-375*r+300) dr dr limits: 0-0.8; 0-0.8
((-375*(r^2))/2) + 300*r limits 0-0.8
ANS: 120
integrate 120 wrt r, 120* r limits 0-0.8
ANS: 120*0.8*pi=301 approx
The book says 201 m^3/ s. I know how hey can get it, they can integrate B twice but only solve using the limits once.
So I'm a bit stuck. Is my logic faulty? I must admit its been a while since I cracked open my vector calculus em books. If anyone can walk me through, I would most appreciate it.
A 1000 thank yous in advance,
Quixotron
quixotron is offline
Surface mountable Capacitors/Resistors BOBKA General Electronics Chat 15 13th May 2007 07:12 PM
surface mount soldering techniques Richard Principal General Electronics Chat 5 12th November 2006 04:43 AM
Flux vs Solid Core Solder Wire dknguyen Chit-Chat 6 10th September 2006 04:50 PM
16F84A surface mount Johnson777717 Micro Controllers 4 28th June 2004 05:25 AM
Flux! - It's not a dirty word. Squintz General Electronics Chat 13 10th November 2003 08:58 AM
