Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 31st August 2007, 03:58 AM   (permalink)
Default Put t on the left side? Vc = V * (1- e^(-t / R*C))
It's high school math and I've simply forgotten how. Yes getting old is fun.
I want t (time) on the left side of the equation and Vc on the right.
Bill
Smart Kits build Smart People
Old 31st August 2007, 04:56 AM   (permalink)
Vc/V = 1- e^(-t /( R*C))
e^(-t /( R*C))=1-(Vc/V)
t/(R*C)=-ln(1-(Vc/V))
t=-R*C*(
ln(1-(Vc/V)))
Ron
Roff is online now   Reply With Quote
Old 31st August 2007, 05:22 AM   (permalink)
Well Roff you've earned a Cricket PCB when they're ready.Thanks.
Bill
Old 31st August 2007, 10:40 AM   (permalink)
I get something different:
And please. write your formulas mathematically correct!!! there are braces missing all over the place!
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline   Reply With Quote
Old 31st August 2007, 02:19 PM   (permalink)
Good catch. The "C"s in the right side of the last two equations should be lower case (ideally, all the lower case "c"s should be subscripted). Those were typos. I have edited my original post to reflect this. My results and yours now match.
Some braces are missing in my equations because I copied and pasted William's equation.
I have edited my original post to reflect these corrections.
Ron
Old 1st September 2007, 05:03 AM   (permalink)
Ron,
It would be easier for novices if you eliminated the negative sign.
ie. t = R*C *ln{Vc/(Vc-V)}
Len
ljcox is offline   Reply With Quote
Old 1st September 2007, 05:46 AM   (permalink)
Originally Posted by ljcox
Ron,
For us math challenged members what is and where did the "ln" term come from?
Lefty
Leftyretro is offline   Reply With Quote
Old 1st September 2007, 06:52 AM   (permalink)
Lefty
Look here for explanation:
Its a standard exponential to natural log transform
A couple of simple examples to demonstrate.
Exp(1) = 2.718282
ln(2.718282) = 1.0
Exp(2) = 7.389056
ln(7.389056) = 2.0
http://whyslopes.com/freeAccess/natu...exponenti.html
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 1st September 2007, 10:10 AM   (permalink)
Consider common logarithms, ie. to the base 10.
If y = 10^x then x = log y
Len
Old 1st September 2007, 11:14 AM   (permalink)
Logs are used to get the exponent, here's how it's done:
z = x^y
y = log_x(z)
To get log to the base x:
log_xz = \frac{log(z)}{log(x)}
It doesn't matter whether you use log to the base e or to the base 10 for this.
As far as e is concerned it should be obvious:
x = exp{y}
y = log_e(x) = ln(x)
Screen name: Aloone_Jonez
Old 1st September 2007, 02:02 PM   (permalink)
Ron,
Len, this won't work. The log of a negative number doesn't exist.
Ron
Old 1st September 2007, 04:05 PM   (permalink)
Well, 1-(V/Vc) and Vc/(Vc-V) are reciprocal and have the same sign, don't they?
eng1 is offline   Reply With Quote
Old 1st September 2007, 04:18 PM   (permalink)
eng1. you are wrong sadly (according to my calculations)
Need Help?
Press F1
Old 1st September 2007, 04:23 PM   (permalink)
You just made me realize that there is another typo in my original post (sheesh!).
t/(R*C)=-ln(1-(V/Vc))
t=-R*C*(
ln(1-(V/Vc)))
Should read:
t=-R*C*(
ln(1-(Vc/V)))
I have edited the original post to correct these errors.
Ron
Old 1st September 2007, 04:27 PM   (permalink)
You've tested for equality, but my point was if 1-(V/Vc) is positive (negative) at any instant, also Vc/(Vc-V) is positive (negative) at the same instant because it's the reciprocal.
Len's equation seems correct to me. I got it from Roff's equation applying the formula ln(1/x) = -1*ln(x)
Line Detection Robot using PIC16F877 helmyshahryl Micro Controllers 0 28th August 2007 01:53 AM
Using Low side drivers with high side P-Mos transistors Tradiator General Electronics Chat 8 7th August 2007 08:04 PM
Simple High side N-Channel MOSFET driver clipo General Electronics Chat 10 5th April 2007 03:43 PM
h-bridge high side issolation Sceadwian General Electronics Chat 8 21st December 2006 12:14 AM
Beginner Questions: AC, Impedence, Transistors, and Salving budidharma General Electronics Chat 5 9th December 2004 08:43 PM
