Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 1st September 2007, 04:34 PM   (permalink)
Originally Posted by eng1
You've tested for equality, but my point was if 1-(V/Vc) is positive (negative) at any instant, also Vc/(Vc-V) is positive (negative) at the same instant because it's the reciprocal.
Len's equation seems correct to me. I got it from Roff's equation applying the formula ln(1/x) = -1*ln(x)
As I pointed out above (we were posting at the same time), my original equation was wrong. Sorry, Len.
Ron
Roff is online now   Reply With Quote
Originally Posted by Roff
t=-R*C*(ln(1-(Vc/V)))
Yes, now the argument of the log function is positive
After your correction, an equivalent equation is:
t=RC ln[V/(V-Vc)]
eng1 is offline   Reply With Quote
Old 1st September 2007, 11:06 PM   (permalink)
I'm glad we sorted that out in the end!
Len
ljcox is offline   Reply With Quote
Old 2nd September 2007, 12:36 AM   (permalink)
With apologies to Sir Walter Scott...
Oh, what a tangled web we weave,
When first we practice to... help someone.
Ron
Old 2nd September 2007, 01:32 AM   (permalink)
Well I put the formula into Just BASIC
VDD = 5
R = 649
C = .00018
Vc = 3.125
print R*C*(exp(1)*(1-(Vc/VDD)))
Turns out I've got to use the TLC555 version as it will be eaiser to implement.
Shall we start discussing ideal values for R1 & R2
Bill
Smart Kits build Smart People
Old 2nd September 2007, 01:48 AM   (permalink)
Bill,
I don't understand why you have exp(1)* rather than ln
And it is RC ln{1/(1 - Vc/V)}
Len
Old 2nd September 2007, 02:46 AM   (permalink)
The "Just BASIC" compiler does not have an ln() statement.
exp(1) [2.71828183] seems to work fine, I'll remove the brackets.
Bill
Old 2nd September 2007, 07:38 AM   (permalink)
Bill,
Some Basics consider the 'log' statement as meaning natural logs to base 'e'
Try 'print log(2.71828183)' you most likely get '1', this will confirm that your Basic considers 'log' as a natural log reference.== 'ln'
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 2nd September 2007, 09:17 AM   (permalink)
Originally Posted by ericgibbs
Bill,
Eric, you're right. The manual of that compiler says:
LOG(n) Description:
This function returns the natural logarithm of n.
Usage:
print log( 7 ) produces: 1.9459101
BTW, it would be easy to get natural logarithm of x if you could use only base-10 logarithms:
ln (x) = 2.302585 * log10 (x)
Old 2nd September 2007, 02:27 PM   (permalink)
I never saw the point of the exp function, surly it's easier to do 2.71828183^x.
Screen name: Aloone_Jonez
Old 3rd September 2007, 05:53 AM   (permalink)
Not really.
x ^ y where y is non-integer is calculated as base ^ (y * log-base x).
If base is 10, then x ^ y is 10 ^ (y log10 x). We used to do this with paper, pencil, and a table of logarithms.
If base is e, then x ^ y is e ^ (y log-e x), or exp(y * ln(x)). There are approximating polynomials for doing this on a computer.
tkbits is offline   Reply With Quote
Old 7th September 2007, 01:14 AM   (permalink)
The "ln" is an abreviation for "natural" or "Naperian" logarithms. Named after the Scottish mathemetician John Napier.
http://en.wikipedia.org/wiki/John_Napier
Papabravo is offline   Reply With Quote
Line Detection Robot using PIC16F877 helmyshahryl Micro Controllers 0 28th August 2007 01:53 AM
Using Low side drivers with high side P-Mos transistors Tradiator General Electronics Chat 8 7th August 2007 08:04 PM
Simple High side N-Channel MOSFET driver clipo General Electronics Chat 10 5th April 2007 03:43 PM
h-bridge high side issolation Sceadwian General Electronics Chat 8 21st December 2006 12:14 AM
Beginner Questions: AC, Impedence, Transistors, and Salving budidharma General Electronics Chat 5 9th December 2004 08:43 PM
