| Notices |
| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
| | (permalink (permalink)) |
| I have a tutorial question I'm a little stuck on, if anyone could give me some assistance it would be greatly appreciated The Q: A 200kVA, 660V, 50Hz, 4-pole star-connected synchronous generator has a synchronous reactance of 1ohm per phase. When the machine is operaing at lagging power factor, rated voltage and current, the torque angle What I've got so far: For star-connected I've managed to get this far but I'm stuck on how to get Ef and phi. Thanks for any help or ideas Last edited by Timmymna; 2nd August 2007 at 01:47 PM. Reason: Spelling and hit Submit rather than Preview :P | |
| This is not the solution to your problem but it maybe give you some ideas to solve yours Please forgive me if the terminology isn't 100% correct but I translate it from my Dutch "Elektriciteit Deel III Elektrische machines" handbook from back in 1982!! Given 2 pole, 3 fase, star-connected synchronous generator Reactive power 12MVA Uline = 6300V Total Fe losses = PFe = 160kW Excitation power = Pe = 44kW with 240V DC Resistance/fase = 0.06Ohm Reactance/fase = 0.9Ohm Power factor = 0.8 Asked Joule losses Induced Eg/fase Result Usefull power Pu = Pr * cos phi = 12 * 0.8 = 9600kW Current (fase & line) = Pu / sqrt(3) * Uline = 9600kW / sqrt(3) * 6300V = 880A Joule losses = PJs = 3 * I² * R = 3 * 880² * 0.06 = 139.5kW Total power applied to the generator Pt = Pu + PFe + Pe + PJs Pt = 9600 + 160 + 44 + 139.5 = 9943.5kW Efficiency = 9600 / 9943.5 = 96.5% Ohmic voltage losses = I * R = 880 * 0.06 = 52.8V Inductive voltage losses = I * Xs = 880 * 0.9 = 792V Voltage/phase = Uline / sqrt(3) = 6300 / sqrt(3) = 3630V Induced Eg/fase see attached vector diagram Eg = 4191V In your case you lack the power factor to split the inductive losses But since you know three parameters of the triangle it can be solved U = 381.05V Inductive voltage losses = 174.95V Torque angle = ATAN(0.2) = 11.3099° Hope this helped... | |
| synchronous counter design techniques | ant9985 | Electronic Projects Design/Ideas/Reviews | 7 | 3rd October 2005 02:39 AM |
| Synchronous buck converter design | bryce1 | Electronic Projects Design/Ideas/Reviews | 7 | 9th December 2004 04:59 PM |
| synchronous motor vs generator | iieeahmed | Electronic Projects Design/Ideas/Reviews | 1 | 28th November 2003 03:28 PM |
| 5-bit up/down synchronous counter | LApprenti Sorcier | Electronic Projects Design/Ideas/Reviews | 1 | 23rd November 2003 09:56 AM |
| Help with a synchronous counter | freqman1 | General Electronics Chat | 1 | 14th October 2003 05:03 PM |
