| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
http://en.wikipedia.org/wiki/.999 | ||
Reason: 1/(10^n) represents .000~1 as n approaches infinity limit as n -> infinity(1/(10^n)) = 0 Therefore, .00~1 = 0. These are fundamental laws to mathematics. This is not a debate. | ||
| Ok i think i'm seeing where the confusion lies. there are certain unusual aspects in various number systems that appear as inconsistentcies when those systems are compared against each other. An obvious example is that 1/3 while being simple and discrete appears as the rather absurd 0.3333~ when put into the decimal based system. Likewise putting the same number into the base-2 number system gives even stranger constructs. The thing is, they are all equivalent if properly defined. The problem arises within the definition of a number system or number set. But if we're going to get into a discussion of the finer points of number system theory we're all going to need to explicitly define what types of number systems we're using and speak in the language of mathematicians. Concepts such as real analysis and the like need to be explored. Limits and the like need different approaches than other equations to be properly expressed. I think the problem with this thread is one of communication, we're not on the same wavelength so to speak in discussing our numbers. Realizing this i think i'm going to withdraw from further debate. As a final note. It is true: 0.99~ can equal 1. It is also true that 0.99~ does NOT equal 1 the statements are not contradictory, they just apply under different circumstances that are mathematically self-consistent. | |
| Your reasoning is flawed Quote:
__________________ Len | ||
The proof that convinced me was the sum of an infinite geometric series, ie. ar/(1-r) For 0.9999~, a = 9 and r = 0.1. Thus the sum is = 1.
| It makes a bit more sense logically when I read Quote:
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." | ||
| One of you guys in the ".999... not equal to 1" gang should rewrite the Wikipedia entry. Thousands, yea, millions, of people are being misled by it. You might want to read it first. Last edited by Roff; 1st May 2007 at 05:24 AM. | |
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| Which means you didn't notice the disturbing part. The division pattern follows one of the patterns of valid repeating decimals. The remainder is the same at each step. In the more obvious invalid divisions, the remainder will grow at every step. Last edited by tkbits; 5th May 2007 at 04:34 AM. | |
| It's not a problem for me. The objection is that I didn't reduce the first significant digit fully, as is normally done. Does that make the division invalid? Or, because of the repeating remainders, is it a valid division? | |
| 1-0.9999999... will NEVER EVER be zero That's wrong due to the laws of math The right way to do it is to take the limit of the function That's zero but only when the x-value is undefined | |
| | (permalink) | ||
| For those of you too lazy to read the wikipedia article, here is your proof. Now lets stop arguing about something that is clearly TRUE. | |
