| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
But with an infinite number of decimal places, there is no last digit. I will be interested to see your convergence of an infinite geometric series.
Len |
Your first & last statement say that C = 0.999~ and also that C =1 implying that 1 = 0.999~ which is NOT true. It is true however that Lim (n->inf) {0.999~} = 1 where n is number of repeating 9's. So your statements as they stand are NOT correct and the convergence of the geometric series is not the issue here technically. The geometric series convergence depends on the existence of its limit. You are showing no limits which is why it is wrong. |
ok if 1 does not = 0.99999~ then explain to me;
why is it that 1/3 = 0.333~ 2/3 = 0.666~ 3/3 = 0.999~ 3/3= 1 so 1= 0.999~ Prove this to be wrong |
These have an infinite number of decimal places and so I don't see how you can add them.
Len |
Len Last edited by ljcox; 20th April 2007 at 10:56 PM. |
I think the answer to this issue is in whether the attached series converges to 1 or to 0.9999~.
It is many years since I studied maths that I don't recall how to do the test for convergence of this series and don't have the time to revise it. So if any knows how to do it, please enlighten us.
Len |
I don't believe this post is still going.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
I don't think you understand. When I type 0.999~, it means that the 9s repeat to infinity. Instead of me reinvinting the wheel, here is a page showing the convergence of an infinite geometric series proving that 0.999~ = 1 |
How about an alternate proof?
9 ) 9.0000....
8 1
90
81
90
81
90
81
9....
Len |
As you can see..I just did add them |
Originally Posted by ljcox
Your error is in adding the decimal values for 1/3 and 2/3 These have an infinite number of decimal places and so I don't see how you can add them. Why can't you add two totally normal numbers as: Code:
1 and 2 ? 3 3
Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. |
Rewrite 0.99~ as (1-x)
(1) Therefore (1-x) =0.99~ (2) Therefore x = 0.00~1 (3) Assumption (to be proven later) x != 0 (4) Therefore, although x may be infinitely small is still not 0 (5) so if 0.99~ = 1 (as asserted by OP) then substituting into (1) the statement (1-x) =0.99~ becomes (1-x) = 1. (6) Rearranging gives 1-1 = x (7) therefore x = 0 (8) VIOLATION of original assumption (3) where X !=0 Proof by "Reductio ad absurdum" that 0.99~ does not equal 1 --------------------------------- Proof that assumption (3) in the above proof is itself correct, where x is not 0 (1) Axiom: 1^infinity = 1 (2) (1+0)^infinity = 1 since (1+0) = 1, therefore from (1) it must be 1 (3) base of natural logaritms "e" is give by (1+1/n)^n as n approaches infinity as given by http://en.wikipedia.org/wiki/E_%28ma...al_constant%29 (4) let x = 1/n (5) as n approaches infinity, x will approach 0, therefore x = 0.000~1 (6) substitute (4) into (3) to give (1+x)^n = e since x =1/n and from (3) (1+1/n)^n = e (7) if x = 0 then (1+x)^n = (1+0)^n = 1^n (8) as n approaches infinity 1^n = 1 from statement (1) (9) VIOLATION: if x = 0 then from (3) the base of natural logarithms must be e = 1 from (7) and (8) but this violates (3) Proof that x =0.000~1 is not zero even though it is very small proof by "reductio ad absurdum" ---------------- Therefore from the above two proofs it is shown that 0.99~ is NOT 1 if it were true then from the above proofs the base of natural logarithms should be 1.... you can check your calculator and spreadsheets to show that it is not 1. If this proof doesn't satisfy you i honestly don't think any proof will. Last edited by Glyph; 27th April 2007 at 02:08 AM. Reason: spelling mistake |
I don't care how much of a math geek you are. If you can't come to the realization that .99~ is not 1 without prompting.... There's just no hope for you as a thinking human being
