| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
| IU was hoping you may be able to help me with the following formula: LANT = 0.2 × Length × ln(Length/d - 1.6) × 10-9 × k Where: Length is the total antenna length in mm. d is the trace width in mm. k is a frequency correction factor. LANT is the approximate antenna inductance in Henry's This formula is taken from the following datasheet: http://www.micrel.com/_PDF/micrf102.pdf My question is: What does 'In' stand for? There appears to be no explanation for that variable. Thanks in Advance | |
| ln (LN, pronounced lon) is the logarithmic function where the base is e. When ln is written, it implies base e. When log is written it implies base 10. Something like log2 or log5 (the # are subscript), it means the base is 2 or 5 respectively. | |
| So if I understand you correctly I punch this into the calculator , I would take 0.2 × Length × 10-9 × k then pres exp button and the sum of ln(Length/d - 1.6) | |
| Yes. Have you not learned about logarithms yet? Or there just isn't a special notation for log base e where you are from? EDIT: Just noticed you are from PEI! Well, I don't know if ln exists over there either. You never know. | |
| 'ln' button is available on the scientific calculator right? If there is 'exp' button.
__________________ Superman returns.. | |
| Yes I've learned about logs, just it was about 15 years ago in Highschool, just wanted to make sure I remembered correctly....especially seeing as I couldn't find my 'log' bead on my abacus | |
| THen upgrade to the slide-rule! 10x the processing power in a fraction of the space! | |
| You can buy scientific calculators fairly cheaply nowadays, failing that just use the calculator on your PC - all modern operating systems come with one.
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| what is the formula for luminance(lux) | yuchween | General Electronics Chat | 2 | 24th July 2006 09:58 PM |
| RC time formula | mozikluv | General Electronics Chat | 4 | 7th January 2004 01:32 AM |
| What is the formula of sound wave affected by temperature??? | billy903 | Electronic Projects Design/Ideas/Reviews | 2 | 23rd October 2003 02:43 PM |
| Anyone know a font i could use to make my own formula sheet? | Richie086 | General Electronics Chat | 7 | 23rd April 2003 06:59 AM |
