| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
| this is the problem, there are 4 resistors in a series circuit, and the total power is 20W. one resistor burns out( which should mean that there should zero current or voltage running through the circuit, so I think they mean a short circuit) anyway, what is the power dissipated by the remaining resistors? now the answer is suppose to be 8.9W. but the only way I could get this answer is by dividing 20W by 3( which is 6.67W per resistor) and then adding the 6.67W to 20W and then dividing by 3 again. hence 8.9W dissipated per resistor.( rounded up) this is not making much sense to me. is the answer wrong or I am I just missing some little detail here. any help would be appreciated. north | |
| Is this college work, we don't mind helping you but we won't doo all the work for you. It depends on which resistor burns out and the resistor values. For example if four 5
anyway the only information I'm given is 4 resistors ,in a series circuit, total power is 20W and one burns out( I think it should be short circuit). so I've assumed that each resistor dissipates 5W. I have no choice but to assume this since no other info. is given. maybe the computer question is not valid in the first place? it seems to make no sense. a glich perhaps on the computers side? Last edited by north; 18th February 2007 at 03:00 AM. | ||
| nobody has any idea(s) thought(s) on my problem? surely someone does | |
| hi north, The way I read the question is: Four resistors of equal value,connected in series, have a total dissapation of 20Watts. One resistor goes short circuit, so whats the dissapation per resistor? Working back from the known answer, should give you a clue. 8.9W * 3 = 26.7W total. So (4/3) * 20 = 26.7W Hope this helps, leave the rest to you. EricG | |
| There are no R values given or no voltage. The way i work it out as a 20 watt only question. 20 watts over 4 R's, if one burns out it usually goes open cct, no current flow no power in a series cct dissipated. Say one R short circuited then 20W x 4 R's / 3 working R's = 26.6 watts over 3 R's. The 20 watt dissipated over 4 R's now has to be dissipated over 3 R's. hence an increase in current and wattage by a factor 4 / 3. 26.6 / 3 = 8.86 watts per resisitor dissipated as heat
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. Last edited by RODALCO; 18th February 2007 at 06:45 PM. | |
| There appears to be two possible problems here, firstly the question as posted isn't very clear (this may, or may not, be the posters fault), secondly the question may originally be very badly written, this is all too common in courses and exams!. In the second case you not only have to work out the answer, you have to work out the question as well - and hope you answer the question that they are expecting!. | |
| When resistors "burn out", they rarely become shorted. They may become shorted from other causes, but not from "burning out". I would assume the resistor is open. This also makes the value of the other resistors irrelevant. My guess is that this isn't an arithmetic problem, it's a check on your understanding of series circuits. | |
| It's a simple case of maths logic. Assume that the burnt out resistor is S/C not O/C. Initial power P = V^2/4R = 20 Wwhere V is the supply voltage and R is the value of each res. Therefore, V^2/R = 80 Now, with only 3 R, P = V^2/3R, but we know that V^2/R = 80 Thus P = 80/3 = 26.7 W, and so power per resistor = 26.7/3 = 8.89 W
__________________ Len | |
but I did not know the answer originally( it was a practice exam question). the question was this; " The total power in a series circuit with 4 resistors of equal value is 20 W. if one of the resistors becomes short circuited , what is the total power dissipated by each of the remaining resistors? " I did make sure of the wording this time. thanks for your reply north | ||
he used the equation P(T)=E^2/R 80W=E^2 and hence both your answers agree. boy there are a few ways of thinking towards the right answer thanks though your response is appreciated. Last edited by north; 24th February 2007 at 04:52 AM. | ||
short circuit was the only logical situation. I did work out the answer though , my way. I divided 20W/3= 6.67W per resistor added it to the original W of 20( because it turned out to be a short-circuit, hence an increase in current, therefore an increase in the power dissapated by each resistor) = 26.67W and again / 3 = 8.89W. thanks for your response it is appreicated!! | ||
thanks for your response. it is , as well , appreciated. by the way, and this goes out to all of you that have responsed to my question , is there any vaild reason why my approach is not sound? if not why? to reiterate> I took 20W/3R = 6.67W , then added my answer to the original , total P of 20W , = 26.67W , which is again is /3 = 8.89W per R dissipated. I know I got the right answer but thats not my point , could I use this method again and again? | ||
| The problem with your method is that you don't know how you got the right answer and neither do I. It may be just a coincidence that your method leads to the right answer in this case. Whereas, the method that your tutor and I used is analytical, ie. you obtain the answer by logic and deduction. In your first post, you appeared to know that the answer is 8.9W. In real life, we don't normally know the answer to a problem otherwise it would not be a problem. So you can't do what you appear to have done, ie. juggle the figures until you get the answer. In real life, we have to deduce the answer.
__________________ Len Last edited by ljcox; 25th February 2007 at 02:54 AM. | |
| | (permalink) | ||
you have originally 20W and 4 resistors. there is a short. which implies a decrease in resistance, increase in current which also implies an increase in power. which means that the overall power , or total power has increased. Quote:
for from now on when I come accross this situation there is no reason for me to think , that by my method , one should not come up with the right answer every time. | |||
| Designing power mosfet circuit | Fontaine | Electronic Projects Design/Ideas/Reviews | 10 | 28th December 2003 06:06 PM |
| Help with dual regulated power supply circuit | xitian | Electronic Projects Design/Ideas/Reviews | 3 | 22nd December 2003 03:00 AM |
| My Compaq power supply (PS2014 series) won't turn on! | lee | Robotics Chat | 1 | 17th December 2003 10:37 PM |
| A series regulated power supply | Power-U | Electronic Projects Design/Ideas/Reviews | 28 | 6th April 2003 10:52 AM |
| neon indicator light in a series circuit | whiterabbit | General Electronics Chat | 9 | 31st October 2002 10:14 AM |
