Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 19th October 2006, 12:20 AM   #1
Default Simultaneous equations with 3 variables
We are beginning Mesh analysis in Electric Circuits 1 (Im a graduate from high school with a major in Electronics Engineering, this is college), I remember how to use Simultaneous equations with 2 variables, but I cant seem to remember how to use it with 3 variables.
I have found this page: http://www.themathpage.com/alg/simul...quations-3.htm
But Things dont always go the way as they show it. So do you multiply by the "other number" and add (With 2 variables thats What I do, for example:
3x+5y=2
6x+10y=4
To get rid of x you would multiply the top by 6 and the bottom by -3, and add. Can this be used to get rid of a third variable?)
Overclocked is offline
Old 19th October 2006, 12:56 AM   #2
Any of the three equations can be replaced by a linear combination of those equations and the solution set remains the same.
What you are trying for is to have one equation with a single nonzero coefficient, one equation with two nonzero coefficients, and one equation with three nonzero coefficients. This is called a triangular form. For example
3x + 5y + 6z = 13
     4y + 2z = 7
          9z = 18
for which the unique solution is { -11/12, 3/4, 2}
Papabravo is offline
Old 19th October 2006, 05:19 AM   #3
yeah..from one equation, find an expression for say for example x..then substitute for x so tht u get 2 equations in z and y..and then solve as for a usual 2 variable simultaneous equation..
\"electricity is a good slave, but a bad master\"
nye is offline
Old 25th October 2006, 02:32 AM   #4
There are several methods, the one I like is sum/rest (well, sorry for my poor English :P, it means sum one equation to another so that you can get rid of one of the variables, then get the equation for one of the two remaining ones and finally substitute this in one of the others).
Also you can always use the simplest one: determinants (really good for 3 equations/variables).
Regards,
JJ Enríquez.
La imaginación es el límite.
GeoMX is offline
Old 4th November 2006, 10:05 PM   #5
3x+5y=2
6x+10y=4
These 2 Eq are the same so there is no intersection.
Consider
3x + 5y = 2 -----1 and
6x + 2y = 1 ------2
Multiplty 1 by 2. this gives 6x+10y=4 ----3
Subtract the Eq 2 from Eq 3:-
0x + 8y = 3
Thus y = 3/8
Len
ljcox is offline
Old 7th November 2006, 06:56 PM   #6
3x+5y=2
6x+10y=4
The both equations are equal.
You have 1 equation, and 2 variables. You have infinites solutions.
So, you have to "parametrize".
y = r;
3x+5r = 2
x = (2 - 5r)/3
When r = 0 , x = 0 and y = 0
When r = 1 , x = -1 and y = 1
You have to choose aleatory values, but they need to obey the conditions:
y = r;
and
x = (2 - 5r)/3;
Hayato is offline
Old 8th November 2006, 01:32 AM   #7
So now, What if you have 4 Equations, and 4 Variables? How can that be solved? Is it even possible to solve something like that? Luckly, she just taught us another method-Super Position and Thevanins theorem. I know why she did it, to show us that there are easier ways to solve a circuit, along with the limitations (if any) that exsist in the circuit.
Old 8th November 2006, 02:17 AM   #8
You can take n linear equations in n unknowns and:
a) find a unique solution if it exists
b) find a linear dependance to eliminate an equation
c) find that there are an infinite number of solutions
surprisingly the method remains the same regardless of the value of n.
Old 8th November 2006, 12:22 PM   #9
Or you can solve the equation by the method:
Ax = b then x = [A^(-1)].b
Where 'A' is the coeficient matrix, 'x' is the variables matrix and 'b' is the solution matrix;
The determinant of 'A' != 0;
Or you can use the Gauss Elimination.
Hayato is offline
Old 11th November 2006, 07:01 AM   #10
I agree with this. By this method, you solve the n variables system linear equations. It just find the inverts matrix you can also use Matlab to do that.
Microcontroller Programming Forums:
http://forum.mcuprogramming.com
Answer to your questions!
Microcontroller Programming Blog:
http://mcu-programming.blogspot.com
uC - News, Resources and Tutorials
sci-3d is offline
Old 11th November 2006, 02:36 PM   #11
Yes, it's a nice method to solve n variables linear eq. systems.
Hayato is offline
Old 12th November 2006, 01:51 PM   #12
Its easier if you use an advanced calculator e.g Ti-83 etc, create a 3X4 matrix and enter the co-efficients, then use the rref function prebuilt into your calculator.
klm is offline
Old 14th November 2006, 02:25 PM   #13
It might be easier but you don't actually learn anything.
Pommie is offline
Old 14th November 2006, 10:20 PM   #14
I agree with Mike.
You should be able to do it by the basic method of eliminating variables.
Once you understand that procedure, then use either determinates or the Matrix method.
Len
ljcox is offline
Old 14th November 2006, 10:23 PM   #15
I find McMillman's Theorm very useful also.
Len
ljcox is offline
equations, simultaneous, variables
Doe anyone have a Sheet showing electronics equations? lompa General Electronics Chat 15 8th May 2007 05:52 PM
cblock variables SPDCHK Micro Controllers 2 3rd October 2006 03:24 PM
lookup tablesss VS equations DanD Micro Controllers 15 7th July 2006 07:13 AM
Where is variables located in a PIC? egh01 Micro Controllers 0 22nd November 2003 01:08 PM
Changing variables through serial port pingouin Micro Controllers 1 22nd August 2003 05:11 PM
