Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 28th November 2006, 05:21 PM   #16
You can always do it with a matrix, then work down to row-echelon form (I think that's the correct term). I know most people hate matrices, but that's what calculators are for.
vortechs2k is offline
Old 15th December 2006, 08:34 PM   #17
in my opinion the easiest method would be to use cramer's rule, as we need operate on 3rd order determinants in this case... try these links ::
www.mathworld.wolfram.com/CramersRule.html or
www.purplemath.com/modules/cramers.htm
mkh is offline
Old 24th December 2006, 02:51 PM   #18
Speaking of learning, for just two equations elimination and substitution are easier. Find one and replace it in the other equation.
For 3 equations, use Gauss elimination or Cramer's rule, for more than 3 variables, Gauss elimination still applies however cramer's rule might be difficult. Or you could just start grouping equations and solving groups at a time.
Once learnt, learnt! as for applying it could be a tremendous time waster if you plan to do manually in the exams.
klm is offline
Old 31st January 2007, 10:37 PM   #19
Dunno if this is already mentions:
where it's
Ax+By=C
Dx+Ey=F .........................for 3 equations
for 2 equations, variables
(F-C*(D/A))/(E-(D/A)*B)->Y
(C-BY)/A->X
Ax+By+Cy=D.........for the rest
for 3 equations,vars:
((DFK+BGL+CHJ-LFC-JGD-KHB)/M)->X
((AHK+DGI+CEL-IHC-LGA-KED)/M)->Y
((AFL+BHI+DEJ-IFD-JHA-LEB)/M)->Z
And plz help me on this:
I got these formula from looking at a program once, but I still have no clue how these formulas are derived from this :
Ax+By=C
Dx+Ey=F
lcmvsv is offline
Old 17th February 2007, 10:40 AM   #20
Solving simutaneous equations with three variables can be done with the row-echelon matrix way, or the Cramer's Rule if the matrix satisfy certain conditions.
littletransistor is offline
Old 25th February 2007, 03:13 AM   #21
Ax+By=C ------1
Dx+Ey=F -- ---2
Multiply 1 by D
ADx+BDy=CD -----3
Multiply 2 by A
ADx+AEy=AF-----4
Subtracting 3 from 4 gives
0x+AEy-BDy = AF - CD
So (AE-BD)y = AF - CD
y = (AF - CD)/(AE - BD)
To solve for x, substitute this value for y in your fourth equation.
Now to express y in the form you wrote above, divide the top and bottom lines by A
y = {F - C(D/A)}/{E - (D/A)B}
For 3 variables, you do the same but you need more steps.
Firstly, reduce the three 3 variable equations to two 2 variable ones by eliminating one variable. Then do what I did above to solve for the 2 remaining variables.
Then you can substitute these into one of the original equations and solve for the third variable.
Len
ljcox is offline
Old 6th March 2007, 03:19 PM   #22
I would say that if you know there exist unique solutions then probably the easiest way solve the set of equations is Cramer's rule
thushy is offline
Old 2nd April 2007, 08:42 PM   #23
i will go for cramer rule to solve these problems
salman007 is offline
Old 20th July 2009, 04:48 AM   #24
TI-83 is the way to go! Engr undergrads surely know how to add and subtract by now. In your case, it's a big waste of time to work it out algebraically.
swood30 is offline
Old 20th July 2009, 05:47 AM   #25
do not worry, he will use it after graduation, but for know he needs to know how the things can be done, and how to apply the rules.
Its what your friend in Your mind, what you in your friends mind
aljamri is offline
Old 20th July 2009, 06:41 AM   #26
He has probably already graduated as he asked the question 3 years ago.
Pommie is online now
Old 16th September 2009, 02:24 AM   #27
This is a standar problem with first year students in university here in Australia even though it is supposed to be taught before hand. I have to often teach this as an extra, yet when they see it students tell me "it is simple" then discover how to manipulate formula.
Look outside the square then square it
Sydney is offline
equations, simultaneous, variables
Doe anyone have a Sheet showing electronics equations? lompa General Electronics Chat 15 8th May 2007 05:52 PM
cblock variables SPDCHK Micro Controllers 2 3rd October 2006 03:24 PM
lookup tablesss VS equations DanD Micro Controllers 15 7th July 2006 07:13 AM
Where is variables located in a PIC? egh01 Micro Controllers 0 22nd November 2003 01:08 PM
Changing variables through serial port pingouin Micro Controllers 1 22nd August 2003 05:11 PM
