Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Math and Physics
Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry.
Old 26th September 2006, 03:25 AM   #1
Default Latex Math Equations
Latex is a high-quality system to generate complex math algarithymes that cant be created using normal text formats.
The best way to explain is by showing you.
Example 1:
[ latex ] \int [ /latex ]
 \int
Example 2:
[ latex ] \Large e^x=\lim_{n\to\infty} \left(1+\frac~xn\right)^n [ /latex ]
Some easy reading (joke):
Latex Symbols
Latex AMS math Documentation
For further reading:
http://www.latex-project.org/
http://www.maths.tcd.ie/~dwilkins/LaTeXPrimer/
Electro Tech Online Owner
Need to contact me? Send me a Private Message.
Verification Email didn't arrive? See this thread.
ElectroMaster is offline
Old 26th September 2006, 09:49 AM   #2
Wow this looks cool but it is a little is tricky!
Let's start with something a bit more simple first.
Like how would I do ohms law, what about I = V/R?
I've given it a go but it doesn't work.
I = \frac~VR
How do I get rid of that x?
Alright, I'll rtfm, I'll look at thoush liks you've posted.
if I know the answer.
Hero999 is offline
Old 27th September 2006, 01:23 AM   #3
Yes it is very advanced stuff but its quite fun to learn.
Old 28th September 2006, 07:02 PM   #4
yeah, that 'x=' at the beginning doesn't make much sense. It also doesn't appear to have support for text/multiple equations/etc, ie - it seems to be only for formatting a single equation, which is the important part, but I am guessing the rogue 'x=' has something to do with that... (because it's not something that happens in "normal" latex)
Take, for instance:
Let ( f ) be the function defined by ( f(x) = 3x + 7 ).
taken from the LaTeX primer at:
http://www.maths.tcd.ie/~dwilkins/La.../MathMode.html
and it results in:
rather than the result you see on that webpage.
Electromaster, do you perhaps have a website you could refer us to where we can read about the specifics (limitations, syntax changes, etc) of this forum-oriented LaTeX module?
EEgeek.net
evandude is offline
Old 28th September 2006, 07:38 PM   #5
You're right, I don't know where that x is comming from.
 f(x) = 2x + \frac{x - 7}{x^2 + 4}]
Hero999 is offline
Old 28th September 2006, 09:15 PM   #6
sorry guys. Thats my bad!
I will edit the config!
Old 8th October 2006, 06:26 PM   #7
Just experimenting with a few simple formulae.
X_C=  \frac{1}{2 \pi FC}\
Z = \sqrt{X_C + R}
R2 = R1 \frac{V_{OUT}-V_{REF}}{R1 \times I_{ADJ} + V_{REF} }\
V_{OUT} = V_{REF} \left(1+ \frac{R1}{R2}\ \right)+I_{ADJ} \times R2
This isn't that difficult. I feel I'm comfortable with enough to get by and I'll still need to RTFM every now and the but it's easy when you know how. I'd rather use Latex than have to attach formula generated by Writer, it saves the copy and pasting.
Hero999 is offline
Old 18th October 2006, 04:36 PM   #8
testing import from Maple:
[ latex ]
F={\frac {kq_{{1}}q_{{2}}}{{r}^{2}}}
[ /latex ]
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 18th October 2006, 05:51 PM   #9
Testing:
\large I=\ \frac~VR
\large f=\ \frac~1{2\pi \sqrt {LC}\ }\
bananasiong
bananasiong is offline
Old 18th October 2006, 08:22 PM   #10
what is wrong with my latex commands? sometimes they work but sometimes they dont (my pervious post)
Need Help?
Press F1
Old 19th October 2006, 04:47 PM   #11
Yes it works!!
<br /> F={\frac {kq_{{1}}q_{{2}}}{{r}^{2}}}<br />
You should enter like this:
[ latex]F={\frac {kq_{{1}}q_{{2}}}{{r}^{2}}}[/latex]
[ latex]<br /> F={\frac {kq_{{1}}q_{{2}}}{{r}^{2}}}<br />[/latex]
with no space in front of the word "latex"
bananasiong
Old 20th October 2006, 10:14 AM   #12
haha! got it. i had the latex statements before and after the code but they were on sepperate lines than the code itself (like when writing quotes etc...
was like this:
[lateks]
code
[/lateks]
Need Help?
Press F1
Old 20th October 2006, 09:45 PM   #13
You can actually get vb code to displaty by using [noparse][/noparse] tags, just wrap them around the code you want to display.
For example you can prevent codes from being converted to smilies.
[noparse];) :D :o :) :( :confused: :mad: :p :rolleyes: :eek: [/noparse]
Hero999 is offline
Old 10th March 2007, 01:10 PM   #14
Question Factorise this one please.
I have been troubled by this factorisation sum for quite some time now. Please help me.
/frac{/sqrt{2a^{2}b^{2}+2b^{2}c^{2}+2a^{2}c^{2}-a^{4}-b^{4}-c^{4}}}{4}
~Sir William Stronghold~
Stronghold_2 is offline
Old 10th March 2007, 01:42 PM   #15
Please post a picture of the formula you want; use an easy to use program such as MS Equation for Word or OpenOffice Math.
Hero999 is offline
equations, latex, math
Latex math symbols williB Math and Physics 21 26th October 2007 08:24 PM
Doe anyone have a Sheet showing electronics equations? lompa General Electronics Chat 15 8th May 2007 05:52 PM
lookup tablesss VS equations DanD Micro Controllers 15 7th July 2006 07:13 AM
89c51 32-bit Math calculation garg29 Micro Controllers 1 1st February 2005 06:15 AM
PIC math question Tako Kichi Micro Controllers 4 12th November 2003 03:48 AM
