| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
| | #16 | |
Factorise: (2 a square b square + 2 b square c square + 2 a square c square - a raised to the power of 4 - b raised to the power of 4 - c raised to the power of 4) / 16. The whole expression is under root. Sorry, because the sum is in words.
__________________ ~Sir William Stronghold~ | ||
| | #17 |
For some reason the Latex on this form requires an variable/number followed by an equals sign. For example, you can have: or: But you can't have: or even something simple like: I suppose a + b doesn't make much sense on its own.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by ElectroMaster; 12th October 2007 at 04:01 PM. | |
| | #18 | |
__________________ ~Sir William Stronghold~ Last edited by ElectroMaster; 12th October 2007 at 04:01 PM. | ||
| | #19 |
I meant that Latex on this forum won't let you have: a + b you need to have: c = a + b This means that what you want to do won't work unless you have an = sign somewhere in-between some numbers or variables.
| | #20 |
| Edit: thanks eng1
__________________ Mechanical Engineers make weapons. Civil Engineers make targets. Last edited by 43617373; 20th April 2008 at 06:14 PM. | |
| | #21 | |
![]() Use curly brackets to surrond expressions, like y^2. | ||
| | #22 |
Accurate formula for calculating filter capacitor size on a linear regulator.
| | #23 | |
X = [(A+B+C-D-E-F)/16]^0.5, so if A = 6, B= 5, C = 4 and so on, then X = 0.75? and B, for example, = 2(b^2)(c^2), so if b = 2 and c = 3, then B = 72? so I should come up with a general equation that solves for a, b and c? If that's what you mean, I'll give it a try, but if I can't solve it in 10 pages I will quit. :-) Last edited by Willbe; 22nd August 2008 at 10:32 PM. | ||
| | #24 |
Whay are you responding to a post made over a year ago? Aslo this thread is about the Latex feature of this forum, not maths help.
| equations, latex, math |
| Latex math symbols | williB | Math and Physics | 21 | 26th October 2007 08:24 PM |
| Doe anyone have a Sheet showing electronics equations? | lompa | General Electronics Chat | 15 | 8th May 2007 05:52 PM |
| lookup tablesss VS equations | DanD | Micro Controllers | 15 | 7th July 2006 07:13 AM |
| 89c51 32-bit Math calculation | garg29 | Micro Controllers | 1 | 1st February 2005 06:15 AM |
| PIC math question | Tako Kichi | Micro Controllers | 4 | 12th November 2003 03:48 AM |
