Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > General Electronics Chat > Homework Help
Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum.
Old 7th November 2009, 02:44 AM   #1
Default speaker
hi guys ..
can we replace the 16 ohm speaker with 8 ohm ??
am using the Isd 1110 voice recorder IC
bashekmagroh is offline
Old 7th November 2009, 03:46 AM   #2
Yes, but it will effect the frequency output of the amplifier.
Test it to find out how.
straight answer, har har."
Sceadwian is offline
Old 7th November 2009, 04:01 PM   #3
The datasheet specifies a speaker that is 16 ohms minimum.
If you use an 8 ohm speaker then the IC might be damaged.
audioguru is online now
Old 7th November 2009, 05:02 PM   #4
You could use two 8 ohm speakers in series, but this isn't usually a good idea
Old 8th November 2009, 02:50 AM   #5
You can put two 8 ohm speaker in series but best to use the exact same speakers. Make sure you get the polarity correct, left terminal on one to right terminal on other. If you want to double check put a 9v battery across the two driving terminals. With you fingers lightly on the cone they should both push in, or push out in sync.
Positive battery terminal resulting in cone pushing out is referenced at red or positive terminal of speaker. This is a good check if you have have multiple speaker system like in stereo or multi-channel home theater installation. I always do the battery test when using sets of different manf. speakers, just to be sure.
Audio amps are voltage sources so power being V^2/R, given voltage is same, the amp will put out more power if load is heavier with half the speaker impedance. If the amp is not designed for this power and its heat sink on output devices cannot dissipate the extra power it may damage the amp. The amps power supply voltage may sag with higher peak load causing distortion. Also the speaker needs to handle the extra drive power.
RCinFLA is online now
speaker
Speaker Rumieus General Electronics Chat 2 14th October 2008 12:21 PM
Speaker uaefame Electronic Projects Design/Ideas/Reviews 1 21st May 2008 01:57 AM
Speaker uaefame Electronic Projects Design/Ideas/Reviews 13 12th April 2008 11:40 AM
speaker help... skullshogun Electronic Projects Design/Ideas/Reviews 3 11th April 2008 12:19 AM
Speaker help madmikejt12 General Electronics Chat 10 20th November 2005 06:47 PM
