| Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum. |
| | #31 |
This is from National's data sheet. LM317 can be used as a voltage or current regulator. The LM317 tries to make 1.25 volts between ADJ and Vout. In current mode it will sent current to the load (LED) untill there is 1.25 volts through the resistor. 1.2 ohms = 1 amp 12 ohms = 100mA The regulator needs Vin to be > Vout by a couple of volts. The LM317 will get hot so add a heat sink. | |
| | #32 |
I hav tried above circuit n found that along with constant current this circuit also provides sufficient forward vltg for almost 4 LEDs......... this one is good
| forward, led, voltage |
| LED forward voltage | Berserk87 | General Electronics Chat | 3 | 6th June 2009 03:00 PM |
| How to measure LED Forward Voltage? | cantfindausername | General Electronics Chat | 20 | 19th February 2009 11:36 PM |
| IR Diode Forward Voltage Check | UTMonkey | General Electronics Chat | 7 | 18th August 2008 01:28 AM |
| How to find led forward voltage? | rvk2 | General Electronics Chat | 4 | 7th November 2004 05:30 PM |
| LED Forward Voltage | jrz126 | General Electronics Chat | 9 | 7th October 2004 12:45 PM |
