| Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum. |
Hello, I'm trying to verify that I correctly calculated the power in R5 shown in the circuit below. ![]() I first determined that the voltage over R5 is 4.91 v. Then I calculated power as P = (V^2)/R5 = 4.3 mW. I would greatly appreciate it if anyone could verify my calculations. Thanks! | |
Show us your calculations........
__________________ Eccentric millionaire financed by 'er indoors | |
R5 isnt in parallel with R3/R4......See your third line
| | #6 |
Calc the value of R3 in parallel with R4 (514.29 ohms)....add R2 to that ( 144.29) , then calc that result in parallel with R5...(950.14)...call that Rz Add that to R1... Calc the current Iw thru R1+Rz... then Pdiss in R5 = Iw squared*R5
| | #7 |
Why don't you use mesh analysis? you do the three meshes find the current thru R5, and you're done, it will be very fast if you use a graphing calculator.
| | #8 |
| I'm afraid that I haven't studied mesh analysis at all. But I'll look into that; thanks.
| | #9 |
Actually, what I'm really trying to verify is the following: ![]() for the circuit I originally posted. Thank you. | |
| | #10 |
deleted my answer
__________________ Eccentric millionaire financed by 'er indoors Last edited by Chippie; 29th October 2009 at 09:12 PM. | |
| | #11 |
1 out of 1 members found this post helpful.
As I see it, it's good, you'll get a the result, as long as you don't make a mistake with the numbers.
| | #12 |
Thanks. I'm studying for an exam and this is one of the things that was causing some confusion for me.
| | #13 |
As you see, there's a bunch of people here that can help you, hope you do it good.
| calculating, circuit, power, seriesparallel |
| Driving high-power LEDs in series-parallel arrays | DSGarcia | General Electronics Chat | 0 | 4th December 2008 07:16 PM |
| cal. short circuit power, in a series circuit. | north | Math and Physics | 37 | 7th March 2007 04:33 AM |
| Series-Parallel circuit | Deathshead | General Electronics Chat | 6 | 21st April 2004 05:40 PM |
| Measuring DC Series/Parallel Circuit? | Deathshead | Electronic Projects Design/Ideas/Reviews | 8 | 23rd March 2004 10:39 PM |
| series/parallel connection of power transformer | mozikluv | General Electronics Chat | 4 | 23rd December 2003 09:47 AM |
