| Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum. |
what is purpose of using diode across relay coil?
It suppresses the fly back when the coil is de-energized.
__________________ Mike2545 | |
Take a relay and a battery. Hold one hand (not two hands) across the relay coil. Connect the relay coil to the battery then disconnect it. Your hand will feel the hundreds of volts caused when the current in the inductance of the relay coil suddenly collapses which induces the very high voltage (the flyback voltage). The hundreds of volts will destroy a transistor that drives the relay coil unless the coil has a reverse-connected diode across it which reduces the voltage spike to 0.7V more than the supply voltage.
| coil, diode, purpose, relay |
| a purpose for speacial purpose computer | frommars | Electronic Projects Design/Ideas/Reviews | 17 | 31st March 2009 05:57 PM |
| beginner: wiggle room on the rated coil current of a relay | nyoo | General Electronics Chat | 4 | 29th May 2008 01:17 AM |
| Protecting FET From Relay Coil | Noggin | General Electronics Chat | 6 | 3rd June 2006 03:58 AM |
| Simple question. What is the purpose of diode across 7805 | William At MyBlueRoom | General Electronics Chat | 24 | 14th April 2006 08:26 PM |
| relay coil inductance? | danielsmusic | Chit-Chat | 16 | 2nd October 2005 04:03 PM |
