Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > General Electronics Chat > Homework Help
Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum.
Old 5th October 2009, 08:57 PM   #1
Default Design Help --- Bubba Oscillator
Ok.. I am currently working on a project in which i want to convert a DC signal to AC signal. after much review i decided to go with a bubba oscillator to just obtain a 60 hz signal. my problem is how do i go about using the 12V Dc that i have to obtain that 60hz signal. any helop would be greatly appreciated.
ismith1984 is offline
Old 5th October 2009, 09:43 PM   #2
Connect the 12VDC to your oscillator.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 6th October 2009, 03:57 PM   #3
thank you brown out for that reply, but I dont think the problem is the connecting the supply. I recently successfully connected my circuit but then after i did so and i ran a trial simulation in Multisim i began oscillating after a few seconds and began amplifying the circuit but never stopped. it appears i might have a problem with my feedback loop and help would be greatly appreciated. also any help in deriving the specific 60 hz frequency given your choice of resistor and capacitor using the information below would be greatly appreciated.
this is the info about the bubba oscillator:
Bubba Oscillator | Free Circuit Diagram
Old 7th October 2009, 03:58 AM   #4
The oscillator circuit needs a power supply. Use your 12VDC as its power supply.
But since you did not provide an attachment nor a link to your circuit then we are just guessing that it has a single-polarity power supply.
The Bubba oscillator from Texas Instruments uses a rail-to-rail opamp with a 0.5V bias voltage. Your circuit is probably completely different and maybe uses obsolete parts.
Just guessing since you did not provide enough information.
audioguru is offline
Old 7th October 2009, 05:40 PM   #5
hey guys i am sorry i didnt put more information. i do appreciate you guys responding to my post as your hell is greatly needed and appreciated. anyways i added the multisim file so you guys can let me know where i might be going wrong with this design.
Old 7th October 2009, 05:42 PM   #6
Always willing to share my hell with friends.
ball.
BrownOut is offline
Old 7th October 2009, 05:45 PM   #7
Your zipped file is bad.
Why don't you post the schematic as a PNG file type?
Old 8th October 2009, 05:40 AM   #8
Sorry again guys, it seems i am having more problems providing sufficient information than solving my oscillating problem. anyways i attached both the png file and a pdf file. so i hope this is much better.
Old 8th October 2009, 06:18 AM   #9
Try 1.5M for R3. Are you telling us that this doesn't work in simulation? Of have you built this?
ball.
BrownOut is offline
Old 8th October 2009, 03:56 PM   #10
well it is my intention to build it. but it does not work when i ran a simulation on it . i also tried the 1.5M for R3 and that too does not give any result.
Old 8th October 2009, 05:48 PM   #11
I got it to simulate correctly in LTSpice. I had to do 3 things to make it work:
1) Correct your VCC connection error in the far-left Amplifier
2) Change your R3 to 2 MEG ohms for sufficient gain
3) Make the 6V a rising edge. Because simulators assume all initial conditions are steady, you need some kind on stimulation to get oscillations started. In a real circuit, these conditions usually exist.
ball.
BrownOut is offline
Old 9th October 2009, 06:53 AM   #12
hey brownout, thanks for in information you provided, again i appreciate it very much. i corrected the VCC connection problem as well as changed the value of R3. my only concern is the 6V being a rising input. are you telling me i have to make it a square wave input or someting of that sort. and can you elaborate on your explanation a little bit more cause i did not really understand .sorry for the trouble if any.
Old 9th October 2009, 04:36 PM   #13
The 6V does not need to be a sqaure wave. You can see in the waveform I posted that it is just a rising edge at 100ms (blue trace) and that it remains a constant 6V after that. All oscillators need something to get them started. In real circuits, that can be a switch on transient, or just random noise. Usually, something is there for starting. I've seen other oscillators that include a starting circuit, but these are rare. If you build this circuit, it will probably start correctly. But in simulations, you might need some kind of transient to make it start. Until now, I haven't simulated an oscillator, so I had to learn that too.
ball.
BrownOut is offline
Old 11th October 2009, 08:01 AM   #14
hey brownout, i was able to do everything except simulate the rising edge in multisim. i still ran a simulation but it begins to oscillate and then amplified to infinity so my guess is i have to use the exact conditions as you did. any suggestions on how i can make the 6 volts a rising edge on multisim.
Old 11th October 2009, 04:01 PM   #15
I'm not familiar with multisim. What do you mean it amplified to infinity?
ball.
BrownOut is offline
bubba, design, oscillator
Need help in oscillator design Harros Electronic Projects Design/Ideas/Reviews 22 29th January 2008 08:51 AM
Oscillator Design SeanHatch General Electronics Chat 40 6th January 2008 09:38 PM
need help to design an oscillator vencatesh Electronic Projects Design/Ideas/Reviews 4 25th April 2007 05:35 PM
please help to design crystal oscillator mohammed elzaq General Electronics Chat 3 24th February 2006 02:12 PM
blocking oscillator design jshroff Electronic Projects Design/Ideas/Reviews 0 7th January 2004 07:54 PM
