Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > General Electronics Chat > Homework Help
Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum.
Old 4th November 2009, 11:29 PM   #61
here is a question, if they simply just turn on and off.. what is the purpose of the driver and output transistors.
ismith1984 is offline
Old 5th November 2009, 01:33 AM   #62
The small contacts on the breadboard cannot conduct more than about only 100mA.
Your thin wires also cannot conduct more than 100mA.
But parts of the inverter must conduct 15A!
Get rid of the breadboard and make a pcb with wide traces.
Or wire a circuit with stripboard.
audioguru is offline
Old 5th November 2009, 01:46 AM   #63
A 100W square-wave inverter takes 120W from the 12V battery so the battery current is 10A.
100W at 120V Needs a battery current of 10A.
Each output transistor must conduct 10A. The base current of each output transistor will be about 3A or more.
The CD4047 oscillator can provide about only 10mA max so you need a current booster to boost 10mA to 10A for each output transistor. The driver transistor and output transistor on each side must do that.
Old 5th November 2009, 01:54 AM   #64
Thanks audio guru that was a very nice explanation that i very much appreciated... i will try to get a stripboard with bigger wires
Old 5th November 2009, 01:56 AM   #65
You also need a big heatsink and insulators for the driver and output transistors.
Old 5th November 2009, 03:00 AM   #66
well i happened to stumble on 2n3055 transistors already sitting on some heat sinks. but i just wanted to see whether i could get at least an output before i can think of doing anything. i tried measuring the output on the first set of op amps. it gave me roughly 10 volts like you said but it is not a square wave instead it is just straight dc.
Old 5th November 2009, 01:45 PM   #67
Originally Posted by ismith1984 View Post
I tried measuring the output on the first set of op amps. It gave me roughly 10 volts like you said but it is not a square wave instead it is just straight dc.
Sorry, I was wrong. The base-emitter Diodes of the driver and output transistors limit the output voltage of the opamps to 1.2V to 2.2V.
since you have 10VDC then the transistors are the wrong ones, or they are connected backwards or they are blown up.
Did you use an LM358 dual opamp?
Do you have square-waves at the outputs of the CD4047 IC?
Old 5th November 2009, 06:45 PM   #68
yes i have a square wave at the output of the cd4047. it works perfectly. it give me and output voltage of about 12V something like that.
Old 5th November 2009, 06:46 PM   #69
i have a question about my 1k resistors and my 4.7 k resistors. i am guessing they should be very high power resistors meaning that they are required to be very big since you said that a total of five volts is coming out of them.
Old 5th November 2009, 06:47 PM   #70
the op amp i curently have is the LM358N is that the right one i need to be using.
Old 5th November 2009, 07:08 PM   #71
got a battery.... got a battery that might deliver the desired output current..... but it ready 12V output but the current reading is 275 - cranking amps and 230 - cold cranking amps... that is all i see.
Old 5th November 2009, 07:17 PM   #72
No.
1/4W resistors are fine.
The 1k resistors have a max of 1V across them so they dissipate only 1 squared /1000 ohms= 1 milli-watt for half the time. Up to 250 milli-watts is allowed for a 1/4W resistor.
The 4.7k resistors have almost no current so they do not get warm.
You need to fix the problem of the transistors that causes the output voltages of the opamps to be DC at a voltage much higher than normal.
Old 5th November 2009, 07:29 PM   #73
It is a car battery that is not good for an inverter. It is designed to deliver up to 275A for a few seconds to start a car's engine. You need a "deep discharge" battery designed for motor homes instead. The car battery is destroyed if it is discharged too much.
Old 6th November 2009, 06:40 AM   #74
yes i figured as much..... i looked around and there was nothing else available. the only thing i got for now ( which i will only use for testing purposes) is a 12 volt battery that delivers 5 amps. will that work or will i need to get two of them since you said that battery needed to deliver 10amps of current. also i didnt make so much progress on trouble shooting the voltage at the op-amp today as it was a really busy one. i will tackle it tomorrow most definately.
Old 6th November 2009, 03:10 PM   #75
A 12V/5Ah battery can supply 12V x 5A= 60 Watts for about 20 minutes. It can supply 3 Watts for 20 hours. The inverter will have a max output power of 50 watts and will heat with 10 Watts.
What will you power with the inverter? Its output is a square-wave that will not power many electronic things.
bubba, design, oscillator
Need help in oscillator design Harros Electronic Projects Design/Ideas/Reviews 22 29th January 2008 08:51 AM
Oscillator Design SeanHatch General Electronics Chat 40 6th January 2008 09:38 PM
need help to design an oscillator vencatesh Electronic Projects Design/Ideas/Reviews 4 25th April 2007 05:35 PM
please help to design crystal oscillator mohammed elzaq General Electronics Chat 3 24th February 2006 02:12 PM
blocking oscillator design jshroff Electronic Projects Design/Ideas/Reviews 0 7th January 2004 07:54 PM
