Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > General Electronics Chat > Homework Help
Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum.
Old 30th October 2009, 06:37 AM   #46
Yes we can use the TL494 for the PWM generation.
One more thing can I use SG3525 for PWM generation.
I need to check first whether these two IC's are available in my place.
If not available I planned to use the ATmega8 uC for PWM generation.
The inverters power output is 300W. So the input is 12V and 25 Amps. Please tell me which MOSFET can handle this much current. Or can I use bank of MOSFETS for this much current.
Whether single MOSFET or bank of MOSFET which is better?
What is the deadtime concept in handling the MOSFET?
prabhueng is offline
Old 30th October 2009, 02:13 PM   #47
Almost any low voltage Mosfet will pass 25A. Some have a very low on-resistance so they will not have much loss and will not get too hot.
Maybe use 50A or more Mosfets so that they will survive if the inverter is overloaded. Then a circuit breaker will have enough time to blow.
Deadtime allows one side to turn off before the other side turns on to avoid an extremely high current from the supply voltage to ground.
audioguru is offline
Old 1st November 2009, 08:23 AM   #48
Hi audioguru
I got both TL494 & SG3525 chips for Rs24.
Also I choosed to use IRFZ48 MOSFET for the DC-DC conversion step.
Now I reading the TL494 examples to construct the DC->DC conversion circuit design.
After constructing the circuit I will post it.
Now my major confusion is selecting the transformer?
Please share me any idea for the transormer selection.
Specification is
primary
V=12
A=30
Secondary
V=350
A=2
Because I am using the PWM with high frequency means I can use the Ferrite core. But what is the standard or the size of the Ferrite core?....
Old 1st November 2009, 02:38 PM   #49
I have never used and never made an inverter so I cannot help your design.
Old 2nd November 2009, 05:03 AM   #50
i have a question once more..... for the astable vibrator in the attached diagram, what formula is used to calculate the frequency with which it switches the signals.
ismith1984 is offline
Old 2nd November 2009, 03:15 PM   #51
You simply look at the datasheet for the CD4047 and it tells you everything about it.
The datasheet from Texas Instruments has more details than from other manufacturers. It has the formula and many graphs showing accuracy when the temperature, supply voltage, frequency, capacitor value and resistance is changed.
Note that the oscillator runs at double the output frequency because it hase a frequency divider so that its outputs have exactly 50:50 duty-cycle.
Old 4th November 2009, 07:16 PM   #52
a quick qestion guys, i built the inverter circuit in its entirety i think. but when i powered it on i realise that the power supply 12 dropped to 0 which i think is more or less a failsafe if there is a problem. i rechecked the wiring and everything seems fine. i my say that i used a 24 volt secondary center tapped and i noticed that the a stable vibrators oscout is not connected to anything. is it supposed to be that was? any suggestions as to why the circuit does not give any output on the oscilloscope?
Old 4th November 2009, 07:17 PM   #53
schematic of inverter....
Old 4th November 2009, 08:16 PM   #54
There is no power supply. The 12V comes from a powerful lead-acid battery. If the 12V drops to 0V then your battery is not charged or the 15A fuse is blown.
I noticed that the astable vibrator's oscout is not connected to anything. Is it supposed to be that was?
The OSCOUT is not used. The Q and Q-not outputs are at the mains frequency.
The Q and Q-not outputs of the CD4047 should show a square-wave at the mains frequency with an amplitude of 13V.
The outputs of the opamps should show a square-wave at the mains frequency with an amplitude of about 1.2V to 2.2V.
The collectors of the output transistors should show a square-wave at the mains frequency with an amplitude of about 22V.
Last edited by audioguru; 5th November 2009 at 01:40 PM. Reason: The output level of the opamp was wrong.
Old 4th November 2009, 08:59 PM   #55
I am actually not using a battery. i am actually testing it using a power supply. let me post you a setup in a minute
Old 4th November 2009, 09:03 PM   #56
this is the setup as you can see there is not battery connected just a power supply.
Design Help --- Bubba Oscillator-1104091500a.jpg   Design Help --- Bubba Oscillator-1104091500b.jpg
Old 4th November 2009, 09:36 PM   #57
You cannot make an inverter on a breadboard!
The contacts are ruined where you forced the huge pins on the 2N3055 transistors into them.
Them and the other connections cannot conduct 15A and neither can your thin wires.
I doubt that your power supply can supply 15A.
There is no heatsink on the power transistors and driver transistors!
Old 4th November 2009, 09:43 PM   #58
ok now i am setting it up piece by piece. i get vp of 13 volts on the q and qnot outputs. i think the problem might be in the amplifier circuit.
Old 4th November 2009, 09:55 PM   #59
There is no amplifier. Just a pair of driver transistors and a pair of output transistors.
They simply switch on and off, they do not amplify.
Old 4th November 2009, 11:27 PM   #60
so you recommend i used bigger wire on the over circuitry or just on certain parts of the amplifier
bubba, design, oscillator
Need help in oscillator design Harros Electronic Projects Design/Ideas/Reviews 22 29th January 2008 08:51 AM
Oscillator Design SeanHatch General Electronics Chat 40 6th January 2008 09:38 PM
need help to design an oscillator vencatesh Electronic Projects Design/Ideas/Reviews 4 25th April 2007 05:35 PM
please help to design crystal oscillator mohammed elzaq General Electronics Chat 3 24th February 2006 02:12 PM
blocking oscillator design jshroff Electronic Projects Design/Ideas/Reviews 0 7th January 2004 07:54 PM
