+ Reply to Thread
Results 1 to 10 of 10
Thread: Why does the hfe changes?
  1. #1
    Karkas Newbie
    Join Date
    Aug 2009
    Location
    Latin America
    Posts
    134
    Default Why does the hfe changes?
    Hi, this is for an electronics lab report.
    I've made three graphics for the output characteristics (for Ib=5ľA, 15ľA and 40ľA) and thre for the input characteristics (for Vce= 2V, 4V and 6V) for an NPN transistor (2N3904), and calculated the hfe for two ponits Ib= 15ľA; Vce= 2V and Ib= 40ľA; Vce= 6V, the first was 220 and the second was 232, of course these values read from the output characteristics graphic, i know that hfe will change if I give a higher base current, and if I have a higher collector emitter voltage, but what other factors can make it change how it changed in my practice?
    Thanks.
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Temperature changes also change the hFE of a transistor. It causes "thermal runaway".
  3. #3
    Karkas Newbie
    Join Date
    Aug 2009
    Location
    Latin America
    Posts
    134
    Well i have to make a report of that, and i know that it changes as the base current and colector emitter voltage change, now with that i can say too that the temperature also affects it, but is there another factor?
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by Karkas View Post
    Silicon transistors have a max allowed emitter-base voltage (when the voltage is the reverse of what is normal). It is 5V to 7V. If the voltage is exceeded in a circuit continuously or for many times then the junction is damaged and the hFE is permanently reduced.
  5. #5
    Karkas Newbie
    Join Date
    Aug 2009
    Location
    Latin America
    Posts
    134
    Thanks for the answer, it will be useful. But wouldn't it be 0,5 to 0,7 V?
    I mean the base emitter voltage.
    Last edited by Karkas; 18th September 2009 at 10:40 AM. Reason: incomplete answer.
  6. #6
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Normally the base-emitter junction of a transistor is forward biased so it conducts like a diode with a 0.7V voltage drop.
    But if the base-emitter junction is reverse biased then it breaks down with what is called Avalanche Breakdown at 5V to 7V.
    The datasheet for every silicon transistor lists the max allowed reverse voltage called "VEBO, Max Emitter-Base voltage" and is 6V for the 2N3904.
  7. #7
    BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent
    Join Date
    Jun 2009
    Location
    Huntsville, Alabama USA
    Posts
    2,174
    Thanks.
    Did you notice that the graph of output characteristics is non-linear? What method are you using to calculate hfe? This quantity is defined as the tangent of the operating point on the curve. Any two points on the curve will have different tangents.
    Lions and tigers and bears, OH MY!
  8. #8
    Karkas Newbie
    Join Date
    Aug 2009
    Location
    Latin America
    Posts
    134
    Quote Originally Posted by BrownOut View Post
    Yes i know that, i calculated it finding the Ic for the Vce specified, and for the constant base current y calculated it by using β=Ic/Ib, i know that if i take another value of Vce in the same graph hfe would be different, but the change is considered insignificant, and we make the aproach to lines with slope 0.
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    2,174
    Well there's your answer.
  10. #10
    Karkas Newbie
    Join Date
    Aug 2009
    Location
    Latin America
    Posts
    134
    Thanks for your help.
+ Reply to Thread
  1. Different hFE for different Vce,Ic.
    By alphacat in forum General Electronics Chat
    Latest: 27th June 2009, 08:10 PM
  2. BC547 hfe
    By davidbear in forum Datasheet/Parts Requests
    Latest: 19th January 2009, 07:31 PM
  3. hFE vs. Beta
    By DigiTan in forum General Electronics Chat
    Latest: 24th November 2005, 01:02 PM
  4. hfe
    By danielsmusic in forum General Electronics Chat
    Latest: 17th August 2005, 10:37 PM
Tags for this Thread
