Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > General Electronics Chat > Homework Help
Homework Help If you have a question about an electronics exam, course or paper you can ask in this forum.
Old 2nd July 2009, 11:40 AM   #1
Default Common emitter amplifier.
When performing a large-signal analisys in a CE amplifier, the load (RL) is being neglected, since it is said that the BJT will be biased so the DC collector current will be equal to the DC supplied current from VCC (V+ in the picture), and therefore RL would be seen to have an inifinite resistance.
I dont understand this since if you connect the load to the amplifier, then according to KVL: V_RL = VOUT.
If V_OUT = 2.5V DC for example, then according to Ohm's law, I_RL = 2.5V / RL.
So how come it is said that no current is flowing through RL?
alphacat is offline
Old 5th July 2009, 07:39 PM   #2
I dont see any RL in that diagram, so perhaps they are talking about setting
the bias point. The DC bias point for an AC coupled output would not include
the load resistance.
MrAl is offline
Old 7th July 2009, 06:58 AM   #3
here Vout = Vce = V_RL. If the BJT is biased so that Vce is zero, then there is no drop across the load.
sfink06 is offline
Old 7th July 2009, 09:04 AM   #4
Thank you very much guys.
What does it mean AC coupled output?
alphacat is offline
Old 7th July 2009, 09:15 AM   #5
Its where the output signal is connected to following circuit via a capacitor.
The 'dc' voltage level is effectively blocked by the capacitor, which only allows the 'ac' signals to pass thru.
ericgibbs is offline
Old 7th July 2009, 09:48 AM   #6
I see thank you.
I always thought that what you said refers to DC coupled output.
What is DC coupled output then?
alphacat is offline
Old 7th July 2009, 09:51 AM   #7
I see thank you.
A 'dc' coupled circuit can be as simple as piece of wire from the output of one stage to the next or a resistor coupling.
Old 7th July 2009, 10:12 AM   #8
Thank you
alphacat is offline
amplifier, common, emitter
Common Emitter Transistor Amplifier caffine General Electronics Chat 2 19th April 2009 11:10 PM
Common Emitter Amplifier - AC Impedance in bugmenot General Electronics Chat 6 18th September 2008 10:24 AM
Common Emitter Amplifier Help Callo1234 General Electronics Chat 9 25th April 2008 09:48 AM
Single Stage Common Emitter Amplifier ad353 General Electronics Chat 2 7th June 2004 05:52 PM
