Project
  1. #1
    Dragonsniper108 Dragonsniper108 is offline
    Project
    Hello everyone I am making a solar rechargeable battery USB thing. I got all the parts and I know that a USB out put Is about 5V and is .500mAmps. My solar plane out put is about 6V and it's current is about 1amps. My batteries are two D cell and there out put together are about 2.5 and it's current is about 7.6Amps. I connect my solar plane to a Diode to stop the flow to go back which then is connect to the postive connection of my battery holder then to a resistor (4.7) which lowers the current to about .550mAmps. Which will go to my female side of the USB. and then complet the circuit by connecting the negative to the negative end to the battery holder and solar plane. Now the problem is that my friend is saying that I need to add a voltage limitar on it right between the solar plane and the battery holder. If I do how would do this?
    P.S i know I need to double the batteries and the resistor but overall do i need the voltage limitar in it or no?
  2. #2
    audioguru audioguru is offline
    The rechargeable battery cells limit their voltage. But you need something to detect a full charge then reduce the current to a trickle.
    +1
  3. Thread Starter #3
    Quote Originally Posted by audioguru View Post
    how do I do that please explain thanks or should I make a LED detection thing that will tell me when it is fully charge (still don't know how to make (-_-))
    0
  4. #4
    Most people use a battery charger IC to properly charge a battery. Maxim and many other semiconductor manufacturers make them.
    0
  5. Thread Starter #5
    thanks but I still don't know how to put that into my circuit
    0
  6. #6
    Quote Originally Posted by Dragonsniper108 View Post
    To properly charge a battery then use a battery charger IC. Its datasheet will show how to do it.
    Pick a battery charger IC for the type of battery you have (lead-acid, Ni-Cad, Ni-MH or Lithium).
    0
  7. Thread Starter #7
    ok will do
    0
  8. #8
    colin55 colin55 is offline
    You need to connect the solar panel to the D cells (via a diode) and include a multimeter set to current.
    Pick a sunny day and let us know the current after about 30 minutes. Then we can advise you of the value of a simple current-limiting resistor or otherwise.
    0
Project: Strobe Light ElectroMaster Electronic Projects 19 2nd November 2008, 12:38 AM
Idea for a project sumitkaul Electronic Projects Design/Ideas/Reviews 9 3rd August 2007, 08:35 AM
IR project for beginner Anonymous Electronic Projects Design/Ideas/Reviews 3 16th January 2007, 09:57 PM
stun gun project:i need help please wes General Electronics Chat 1 18th August 2002, 03:23 AM
Building a helmet to helmet communication project Anonymous General Electronics Chat 1 12th July 2002, 04:15 AM
Page Time: 0.09740 seconds      Memory: 7,506 KB      Queries: 16      Templates: 0
