+ Reply to Thread
Results 1 to 4 of 4
Thread: electronic distance measurement
  1. #1
    tomas632 Newbie
    Join Date
    Aug 2009
    Posts
    24
    Default electronic distance measurement
    Hi Guys,
    I am doing an electrical project for college which involves an RC helicopter. I've been asked to implement a control loop to get it to hover at a set height with movement commands coming from the handheld controller. All that is autonomous is the height it should be flying at. I've been looking at ways to measure distance from the heli to the ground, but have not been very successful. The majority of cheap ultrasonic sensors are AC input and so I would need to somehow convert my DC supply to AC, which is a bit impractical. Also from looking at other discussions about accelerometers being used seems to suggest accuracy will be awful. Does anyone have any suggestions for a device that will be able to convert the distance from the heli to the ground into an electrical signal that i can feed into my control loop?
  2. #2
    vne147 Okay
    Join Date
    Jan 2007
    Location
    Houston, TX
    Posts
    656
    What will be the maximum altitude of the helicopter? I have used a distance sensor like this before. They are very easy to use.
  3. #3
    tomas632 Newbie
    Join Date
    Aug 2009
    Posts
    24
    Quote Originally Posted by vne147 View Post
    Hi, we are going to be using these over about a 1m range so looks ideal.
  4. #4
    vne147 Okay
    Join Date
    Jan 2007
    Location
    Houston, TX
    Posts
    656
    I also found this one at the same site. It senses distance between 0 - 6.5m The first IR based sensor that I linked consumes about 33 mA but this one only uses about 2 mA. I'm not sure what kind of helicopter you are going to use but if it's one of those cheap foam ones, the current draw might make a significant difference. Good luck!
+ Reply to Thread
  1. Laser distance measurement. Please help!
    By luckyvn in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st October 2009, 03:54 PM
  2. distance measurement
    By kpshamilsagar in forum Micro Controllers
    Latest: 17th September 2009, 12:37 PM
  3. Distance measurement project
    By bigfarmerdave in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th December 2007, 06:42 PM
  4. Modulated IR distance measurement
    By samarsingla in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th December 2006, 03:27 PM
  5. Methods of distance measurement?
    By dave3141 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd April 2006, 03:38 AM
