Modern HF fluorescent lighting
  1. #1
    danrogers danrogers is offline
    Hi all, I'm looking at the advantages of modern high frequency lighting over older low frequency lighting (mains frequency).
    I need to compare primarily the economics of the two. I have been googling for a few hours but not managing to find much of use.
    Can anyone point me in the right direction, or has their own personal views/experiences?
    Many thanks
  2. #2
    alec_t alec_t is offline
    The comparison may give different results depending on such things as total wattage and whether or not the lights are to be dimmed. Can you be more specific as to the lighting systems you want to compare?
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  3. #3
    Diver300 Diver300 is offline
    Quote Originally Posted by danrogers View Post
    In my experience, the HF ones are easier to work under, as the 100 Hz flashing of standard lights affects a significant proportion of people, including me. The economics don't come from reduced energy use.
  4. #4
    Well I just need compare the older low frequency ballasts with the newer ones that run at something like 30KHz.
    I need to compare them mainly from a economic point of view, with regards to the cost of manufacture, cost of disposal, length of service cost to purchase etc. It is a big of a vague assignment really (I'm studying HNC electrical & electronic engineering).
    0
  5. #5
    MrAl MrAl is offline
    Are you including the required bulb holder in the older type for the cost comparison? That was a significant part of the cost back then.
    0
    One test is worth a thousand expert opinions, but one expert specification is worth a thousand tests.
  6. #6
    Hi MrAl, I will be looking into all aspects of the lights. Thanks for the input - when you say bulb holder do you mean the compact flouro bulbs or the tubular fittings?
    0
  7. #7
    duffy duffy is offline
    You shipping overseas? We changed to electronic ones at work a few years back because they will automatically switch 120/220V, one part to stock, one less thing to keep track of.
    0
    Please respond to items in forum, not in private messages.
  8. #8
    I meant the ones that do not screw into a base, like the tube bulbs yes. The screw in ones dont require a special fixture so that might make a difference in the cost to some people.
    0
building an emergency lighting system adeola mojisayo Electronic Projects Design/Ideas/Reviews 1 21st December 2003, 06:56 PM
RGB LED Home lighting project BrianK Electronic Projects Design/Ideas/Reviews 6 9th November 2003, 07:21 PM
switching/controller box for stage lighting Robin Electronic Projects Design/Ideas/Reviews 2 25th October 2003, 03:31 PM
Lighting problem buloi123 General Electronics Chat 3 30th September 2003, 07:10 PM
RE:- help!! AC switch mode supply for low voltage lighting mikegaylor Electronic Projects Design/Ideas/Reviews 1 19th April 2003, 02:10 PM
Page Time: 0.06108 seconds      Memory: 7,194 KB      Queries: 17      Templates: 0
