+ Reply to Thread
Results 1 to 2 of 2
Thread: Transformer Configuration
  1. #1
    Within a AC to DC / DC to AC inverer there is a delta - star 3 phase transformer which steps up 110Vac to approx 450Vac when working in the direction of DC to AC.
    The inverter powers mainly induction motors, lighting circuits and other machinery.
    The DC end is supported by a 250Vdc battery.
    Why has a delta - star configuration been chosen and what are the advantages?
  2. #2
    The delta-wye is great for stepping voltages up. A delta has phase current of only 57.7% of the line current, but phase voltage is equal to line voltage. The 57.7% is just 1/sqrt3.
    A wye has phase voltage of 57.7% of line voltage, with phase current equal to line current. Thus a wye requires less insulation at higher voltages, and a delta requires less copper at higher currents.
    The low voltage side of any transformer carries the higher current. Thus delta is great for low V high I, and vice versa for wye. However, there is no reason why it couldn't work the other way around. The transformer would be slightly larger or the regulation would be slightly reduced, but it would work just fine.
    For stepping up, delta primary w/ a wye secondary is optimum regarding regulation vs. size/weight. Again, other configurations like Y-D, D-D, etc. can also work.
    Claude
+ Reply to Thread
  1. PIC18F4431 Configuration
    By 2exposantThom in forum Micro Controllers
    Latest: 29th October 2008, 09:20 AM
  2. Diode configuration
    By Armagdn03 in forum General Electronics Chat
    Latest: 8th March 2008, 05:17 PM
  3. configuration bits
    By frustration in forum Micro Controllers
    Latest: 30th April 2007, 12:43 PM
  4. transistor configuration
    By Gaston in forum General Electronics Chat
    Latest: 18th January 2007, 05:27 AM
  5. PIC16F84 configuration
    By 4electros in forum Micro Controllers
    Latest: 23rd October 2006, 05:19 PM
Tags for this Thread
