I need a circuit, when it get triggers it will turn the output after a delay.Delay determine by the values of R & C. Is this circuit works? Last edited by Suraj143; 11th November 2009 at 03:58 AM. | |
Does the trigger stay high longer than the desired delay, or is it a momentary pulse?
__________________ Mike ML. | |
Trigger comes from the door contact unit (dry output) When the door open after the delay it will sound the buzzer. But if the door open & close suddenly it won't sound the buzzer. Last edited by Suraj143; 11th November 2009 at 07:35 AM. | |
| Is the door contact normally-closed (contact opens when door is opened)?
| | #5 | |
It uses just about any comparator (LM324, 339, etc.) and any SPST switch that operates with the opening and closing of your door. When the door is closed, the closed switch allows the capacitor in the positive input of the comparator to charge and hold. When the door is opened, voltage is cut off from the cap, and it begins to discharge. When the + input voltage falls below that of the - input, the comparator turns on and activates the buzzer. The R*C combination can be adjusted to allow a desired delay time. If the door is closed before the comparator is activated, voltage is reapplied to the cap and nothing happens. The attached schematic is a bare bones idea to go by, if you are interested.
__________________ Creationists have a world of evidence | ||
| | #6 |
Hi AllVol that's really what I looking out.Perfect. Thanks for your idea. | |
| | #7 |
| Glad I could help. Hope it works out for you.
| | #8 |
Hi, Can anyone help me with a circuit diagram for my requirement? My requirement is I need to switch ON a motor (6V -DC) for 2 - 3 seconds every 14 days. The rest of the time the motor is OFF. I would highly appreciate if I can get this | |
| | #9 |
| You need to apply a trigger signal to a monostable circuit on every 2 weeks.2 weeks period is pretty higher.Easiest way is to use a RTC with a micro controller with lots of battery backup.
| circuit, delay, time |
| Need time delay circuit | goofeedad | Electronic Projects Design/Ideas/Reviews | 10 | 6th August 2009 10:45 PM |
| Time delay circuit | firealarmfreak | Electronic Projects Design/Ideas/Reviews | 16 | 5th September 2008 05:00 AM |
| Time delay circuit. | mazur50 | General Electronics Chat | 23 | 15th June 2007 10:54 PM |
| Time Delay Circuit | AnthonyWow | Electronic Projects Design/Ideas/Reviews | 7 | 2nd November 2005 11:56 AM |
| Time/delay circuit | bonanz | Electronic Projects Design/Ideas/Reviews | 7 | 27th October 2003 01:59 PM |
