Old 10th November 2009, 04:14 PM   #1
Default inductor current
hi all...... can u tel me how to test an inductor for a particular current....
i mean to say i hav an inductor and current 100mA thru it.. so how can i decide whether the inductor is going to take the current without damage??????????
bublee is offline
Old 10th November 2009, 04:37 PM   #2
It is not a matter of damaging the inductor; it is usually about the current that causes the magnetic flux path in the inductor to saturate, causing non-linearity and unpredictable circuit behavior.
For example, read this data sheet.
Mike ML.
MikeMl is offline
Old 11th November 2009, 07:47 AM   #3
If you only want to avoid damage, measure the DC resistance and use the formula for power. You'll have to use some judgment as to how much power the unit could safely dispose of, but you can get in the ball park.
Example: If an inductor is about the same size as a 1W resistor, and if it measures 2 ohms. I would guess that it could pass ( I = sqrt(P/R) ) where P is 1, R is 2, and therefore I would guess that the risk of damage is low if I keep the current well below sqrt(1/2) or 0.7 amperes.
If the wires are visible, measure their diameter and look it up in a table.
Of course as MikeML said, even if it doesn't burn up it may not work.
de KI6RWX
mneary is offline
Old 11th November 2009, 09:55 AM   #4
Power it up with a DC current and measure the temperature rise above ambient (allow 20 mins or so for the temp to stabilise). At full rated current they are usually less than 30'C above ambient. That will get you in the ball park. Then I would de-rate it maybe 30% to allow for current ripple.
Mr RB is offline
current, inductor
Inductor Current Shunt Alexsgarage General Electronics Chat 3 15th October 2009 05:06 PM
Max Current in inductor. electricity86 Electronic Projects Design/Ideas/Reviews 20 27th March 2009 06:16 AM
Checking for Inductor Current Rating Wond3rboy General Electronics Chat 6 19th January 2009 03:00 PM
Current Through Inductor?? ZIGGY_DAN General Electronics Chat 17 21st June 2006 09:36 AM
High current inductor Oznog Electronic Projects Design/Ideas/Reviews 0 28th November 2005 08:38 AM
