+ Reply to Thread
Results 1 to 3 of 3
Thread: 3.7volt to 6volt
  1. #1
    ama_trig Newbie
    Join Date
    Oct 2008
    Posts
    5
    Default 3.7volt to 6volt
    Anyone have any idea/circuit to build inverter to convert 3.7 volt to 6 volt 40 mA. I want to charge mobile from 3.7 volt battery.
    I've searched Internet, nothing found useful.
  2. #2
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,243
    Blog Entries
    2
    A simple 555 timer IC can be set up to work as a simple charge pump voltage booster. It would likely give you the needed 6 volts or close enough at 40 Ma if built properly.
    "When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
  3. #3
    nickelflippr Good nickelflippr Good nickelflippr Good nickelflippr Good
    Join Date
    Oct 2006
    Location
    Oregon, USA
    Posts
    487
    Perhaps a TL499 boost switching regulator would do it? You may be in no man's land though, because the minimum voltage difference may not work, hard to say with that data sheet.
+ Reply to Thread
  1. 4 AA (6volt) to Lcd rated a 5.5 volts Max
    By 1Steveo in forum General Electronics Chat
    Latest: 12th February 2006, 11:59 AM
  2. simple 6volt power source
    By throttle63 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd August 2004, 07:21 PM
Tags for this Thread
