+ Reply to Thread
Results 1 to 14 of 14
Thread: 555 astable problems
  1. #1
    bkr1969 Newbie
    Join Date
    Nov 2009
    Posts
    5
    Default 555 astable problems
    I am trying to test a simple servo controller with a 555 timer and transistor. I've read every page I can find and I still can't make it work right. I have a variable resistor between R1 and R2 and (both R1 and R2 are 4.7k) and while I can change the pot, the servo continually jitters and moves in small increments, sometimes CW and sometimes CCW. The power indicating LED (5v regulated through LM2940CT) flickers as well and the regulator really heats up. Something is obviously not right. Please help.
  2. #2
    flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent
    Join Date
    Oct 2008
    Location
    Amsterdam
    Posts
    558
    Is the load drawing too much current?
  3. #3
    qdn
    qdn is offline
    qdn Newbie
    Join Date
    Aug 2009
    Posts
    15
    It looks like the current bypass cap you have is not big enough to provide the transient current. Do you have a bigger cap to try, or maybe put a few in parallel, and see if that help.
  4. #4
    bkr1969 Newbie
    Join Date
    Nov 2009
    Posts
    5
    Is that C2? I've been messing with it and once it becomes clear that the 1ms pulse is the low, not the high, I changed my resistor values to R2 = 15k and R1 = 220k and it worked better. Then when I started messing with the caps, once I changed C2 to a 330uF most of the jitters went away. It doesn't seem as straight forward as every site I've read makes it out to be, but it's getting better.
  5. #5
    qdn
    qdn is offline
    qdn Newbie
    Join Date
    Aug 2009
    Posts
    15
    Try a bigger cap on C5.
  6. #6
    bkr1969 Newbie
    Join Date
    Nov 2009
    Posts
    5
    How does that change anything? My voltage coming out of the regulator with the 22uF cap is a steady 4.89. Not doubting you, just don't understand the relationship to the timing circuit.
  7. #7
    ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    Disregard previous comment.
    I think you need to have a seperate regulator for your motor. I have no experience with servos, but other motor applications it is desireable to not have the motor and control circuits using the same supply.
  8. #8
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    How much current does your servo draw?
    Ron
  9. #9
    BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent
    Join Date
    Jun 2009
    Location
    Huntsville, Alabama USA
    Posts
    2,167
    What is the function of the timer? Is it supposed to produce a varying duty cycle? If so, it's not a good design. Also, the wiper of R6 doesn't appear to be connected to anything.
    Lions and tigers and bears, OH MY!
  10. #10
    qdn
    qdn is offline
    qdn Newbie
    Join Date
    Aug 2009
    Posts
    15
    Quote Originally Posted by bkr1969 View Post
    I'm speculating that your servo draws more current than the regulator could supply, and the cap is there to supply those extra current, if that's the case, a bigger cap will be needed.
  11. #11
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,810
    Servos almost always draw more current than a small regulator can supply. Sometimes a big enough capacitor will help, but not always.
    The most robust solution is to provide power to the logic (receiver, 555, or whatever) that comes from a different battery than the one which supplies the servo.
    de KI6RWX
  12. #12
    bkr1969 Newbie
    Join Date
    Nov 2009
    Posts
    5
    Quote Originally Posted by qdn View Post
    So C5 needs to be larger even with C9 being 330uF? My understanding was that the possibility of the servo needing extra current was handled by C9. Sorry, still new to the servo control stuff. I think what I actually need to do is build a circuit using a 556 with the astable side providing the trigger signal and the other side as monostable to produce the pulses (1ms - 2ms). I will try that. Thanks for the help.
  13. #13
    bkr1969 Newbie
    Join Date
    Nov 2009
    Posts
    5
    Quote Originally Posted by BrownOut View Post
    Sorry...mis-drew that. The wiper should actually be wired to pin 7. This is just a test circuit for an animatronic series I'm reading. Eventually the servo(s) will be controlled with a microcontroller chip.
  14. #14
    madhippiescientist Newbie
    Join Date
    Nov 2009
    Posts
    101
    If interested in the Astable/Monostable thing,
    take a look at "Danielsmusic" posted on this same
    date at 07:00.
+ Reply to Thread
  1. Help! Picoscope/Astable Problems
    By circuitfish in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st March 2009, 02:06 PM
  2. 555 -astable mode
    By stevez in forum General Electronics Chat
    Latest: 21st April 2006, 04:12 PM
  3. connecting mono 555 to astable 555
    By dt in forum General Electronics Chat
    Latest: 5th January 2006, 01:34 AM
  4. 555 astable?
    By qyc88 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd July 2003, 11:23 AM
  5. 555 astable question
    By OverTech in forum General Electronics Chat
    Latest: 17th May 2003, 04:44 AM
Tags for this Thread
