I m supposd to build a voltage to frequency converter using only BJTs,resistors n capacitors....no ICs allowed...any ideas????
Create an oscillator and use a varactor diode as a tuning element. A Varactor is just a diode used while reverse biased, I think some transistor junctions can be used effectively (if not ideally) as varactors.
No actually i cant use varactor diode......just BJTs n normal Rs n Cs....
Use the voltage to control a current source. Use the current to charge a capacitor. Put the capacitor inside an oscillator.
__________________ de KI6RWX | |
Does the transfer function (Fout/Vin) need to be linear? If so, it will be considerably more difficult.
| | #6 | |
![]() The circuit should produce a voltage wavefrm whose frequency would increase on increasing the magnitude of an applied DC voltage.....n vice versa....the applied DC voltage is not the DC biasing voltage..... The output need not evn be a proper ac wavefrm..... The circuit myt be constructed using cross coupled bjts,as in a flip-flop,isnt it???? Maybe by placing capacitors of the correct value at the correct places..... | ||
| | #7 |
Ok I was going to ask you if it could be a square wave, because looking through my books all RC oscilators have no real frequency change per voltage change. BUT a multivibrator does. Heres how I would try it, Build a multivibrator, then use a variable resistor in one of the base circuits, then adjust this resistor up and down to see how the freq, changes, once you establish that, then this variable resistor could be substituded with a transistor amp, so then an input to the amp, would cause a change in base voltage at the multivibrator, thereby changing the freq. Last edited by 12345678901234567890; 8th November 2009 at 01:03 PM. | |
| | #8 |
The simplest example I can think of was hinted at by 1234... Build a simple two-transistor astable multivibrator. Instead of connecting the timing (base) resistors to Vcc, connect them to the frequency control voltage. | |
| | #9 |
Here is one I use quite often. It is a Hartley oscillator. You can replace the varactor diode with ordinary diodes such as a 1n914. You can increase the ratio of voltage to capacitance by paralleling diodes in place if D1.
| | #10 |
Voltage controled astable circuit, is do - able For what your application asks for. Last edited by 12345678901234567890; 11th November 2009 at 10:10 PM. | |
| | #11 |
| converter, frequency, voltage |
| constant dc output voltage for frequency to voltage converter | nnb29 | Electronic Projects Design/Ideas/Reviews | 13 | 6th September 2009 01:03 PM |
| Voltage to Frequency Converter | km | General Electronics Chat | 39 | 3rd March 2009 11:54 AM |
| voltage to frequency converter | neelam29 | General Electronics Chat | 2 | 4th September 2006 02:25 PM |
| Voltage-to-Frequency Converter II | km | General Electronics Chat | 43 | 14th July 2006 09:48 AM |
| voltage to frequency converter? | fabienduarte | General Electronics Chat | 5 | 23rd March 2004 12:22 AM |
