Howdy folks!
I have a simple question about connections for a relay. I've looked at a couple of tutorials, but none of them show sample connections etc. Connections that I have for the relay are labeled: 1. NO 2. C 3. NC I'm running a 12VDC in to the relay and I want to switch 12VDC out of the relay. How would I connect my outputs to the labels which are listed above? Also, just for giggles; how would I connect, so that I could use a 12VDC input to switch a 120VAC line. Just so you know, here are the markings on the relay GOODSKY RWH-SH-112D 12A/250VAC ~ | 10A/277VAC~ 15A/120VAC ~ | 12A/250VAC~ 15A/24VDC | 15A/24VDC coil 12VDC 50/60Hz CU Finally, I have a question about the power supply. I'm running from an automotive system, so I want to regulate the circuit power supply (regulate to 12VDC). I'm okay with that, the question that I have is, since the relay is only rated at 24VDC, should I regulate the line that I want to switch with the relay? (Some say voltage spikes up to 60 volts depending on the regulation of the alternator). Finally, I swear Thanks for your help! |
(permalink) | |||
NO = normally open, wich means it isn't connected to common if the relay is not powered, when the relay gets power it will connect to common NC = normally closed, the opposite of NO Quote:
cars are stuffed with relays, a 12VDC relay should work just fine |
great! Thanks EXO!!!
