components graph question..
  1. #1
    transgalactic transgalactic is offline
    http://i38.tinypic.com/xdxsuv.gif
    1.
    i know that a diode is short circuit when the currect threw it is positive
    and open circuit other wise
    but the graph of it says
    when the current goes from zero till infinity
    the voltage is zero (which is fine)
    but
    that on current 0 the voltage goes from zero till minus infinity
    what does it mean " zero till minus infinity"?
    i cant see how it means open circuit
    2.
    why a battery gives a constant voltage no matter the current?
  2. #2
    JimB JimB is offline
    Quote Originally Posted by transgalactic View Post
    1.
    When (conventional) current flows through a diode from anode to cathode there is a voltage drop across the diode. This volt drop is fairly constant with only a slight increase when the current is increased.
    What about reverse (zener) breakdown?
    It is a bad idea to think of the normal operating behaviour of a diode as being short circuit or open circuit.
    The graph is an ideal representation, real diodes dont behave exactly like that.
    but that on current 0 the voltage goes from zero till minus infinity
    Zero = the integer number between +1 and -1, (1 + (-1) = 0
    till = Norwegian/Swedish for the English word "to"
    minus = denotes a negative number
    infinity = a very large number
    Exactly, it does not.
    You only think this because your basic understanding and terminology of a diode is wrong.
    Only an ideal thoretical battery works like that.
    For a real battery, the terminal voltage will drop as the current drain increases.
  3. #3
    Karkas Karkas is offline
    He's talking about an ideal diode, when it is fowrard biased the voltage across a diode (a real one) is +/-0,7V for a silicon diode, and it is fairly constant as JimB said, when it is reverse biased the current is so small (units of nA) that it is considered an open circuit, and you will measure any voltage (untill it reaches its breackdown voltage which is also the minimum voltage it needs to conduct in reverse ).
    0
  4. Thread Starter #4
    i use only ideal components
    "zero till minus infinity"
    i ment i cant understand the physical meaning of this part in the graph
    0
  5. #5
    MrAl MrAl is offline
    Zero to minus infinity simply means that the voltage *may* be anything between
    zero and minus infinity. When the voltage across the diode is minus, the diode
    does not conduct. A few examples:
    v=-1, i=0
    v=-2, i=0
    v=-100000, i=0
    So the voltage can be minus anything and the current will always be zero.
    They seem to be saying that when the voltage across the diode is zero
    it conducts (and the amount of current would depend on the external circuit).
    They should have specified that 'v' is the voltage across the diode itself,
    not the input voltage v to the circuit as it is drawn.
    0
frequency vs voltage graph confounded General Electronics Chat 20 6th April 2009, 12:28 AM
question about the difference between components.. transgalactic Electronic Projects Design/Ideas/Reviews 1 17th May 2008, 07:16 AM
Question about toasting smt components pmichner General Electronics Chat 4 20th March 2008, 07:21 AM
Using excel to plot graph gjpollitt General Electronics Chat 2 20th August 2005, 08:41 AM
Bar-Graph Counter captainkirksdog General Electronics Chat 2 15th December 2003, 12:09 AM
Page Time: 0.05800 seconds      Memory: 7,404 KB      Queries: 16      Templates: 0
