Old 7th November 2009, 01:34 AM   #1
Default Battery choice
Hey guys we all probably used a coin cell battery for etc clocks but is it better to use 2 AAA batteries when size isn't a issue?
AtomSoft is online now
Old 7th November 2009, 01:57 AM   #2
The size of a battery cell determines how much stuff is inside which determines how long it can supply a certain amount of current.
Two AAA alkaline cells can supply 25mA for 40 hours when the voltage has dropped to 2.0V.
Two alkaline button cells can provide 25mA for a couple of minutes or less when the voltage has dropped to 2.0V.
audioguru is online now
Old 7th November 2009, 02:03 AM   #3
thanks!!!!
Old 7th November 2009, 02:29 AM   #4
If size isn't an issue for really low current drain applications think Lithium. Not the common Li-poly cells that are in everything now days, but Lithium primary cells. The have really low self discharge rates, and extreme shelf life, 10 years or better under discharge or not for backup applications. Still able to supply current up until it's end of life for short duration.
straight answer, har har."
Sceadwian is offline
Old 7th November 2009, 05:48 AM   #5
In general, for a particular battery chemistry, (alkaline, lithium, etc.) the larger the battery, the lower the cost per watt hour of energy. So it's generally a trade-off between the cost of battery operation and the room you have for a battery. For alkalines, the AA size seems to be a good compromise for many electronic applications.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 7th November 2009, 05:09 PM   #6
Lithium primaries comes in 1.5volt output in a AA form factor, they're much more expensive than alkalines but for backup applications where size isn't an issue they're king.
battery, choice
Battery choice Diver300 Electronic Projects Design/Ideas/Reviews 7 4th November 2008 02:34 PM
Microcontroller choice GarryJ Micro Controllers 14 25th July 2006 02:46 PM
cable choice GoKid General Electronics Chat 4 2nd June 2006 06:21 AM
Filters Choice? mo7mad General Electronics Chat 4 6th April 2006 02:50 PM
XTAL choice Asjad Micro Controllers 2 17th April 2004 07:17 PM
