Hi All, I was wondering if some one could help me. I have a 0.7V power source and an IC that will run from 0.7V but it initially requires 1.1V. Is there a way I can temporarily increase the voltage from 0.7v to 1.1v during switch on? Thank you in advance! The IC I am using is http://www.microsemi.com/datasheets/lx1732.pdf Last edited by ee0jmt; 6th November 2009 at 04:08 PM. | |
Maybe a voltage doubler like a 555 timer voltage doubling circuit?
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ | |
How about sharing the data sheet of the IC you are using.
__________________ Pay it forward. | |
dknguyen, I don't think a 555 will work as a boost converter at Vcc=0.7v. ee0jmt, What's the IC? Are you intending to run from a small solar cell? ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
The data sheet for the component I am using can be found at http://www.microsemi.com/datasheets/lx1732.pdf | |
| | #6 |
| Only by using a small battery; it doesn't need much capacity, but it would have to isolated once the smps starts running.
__________________ Mike ML. | |
| | #7 |
Wait a minute here. It's not like you have the ability to tell the input to drop to 0.7V after startup. The feature is designed to keep the system working after startup at 1.1V down to 0.7V. You realize that when the input drops to 0.7V, the chip has to work harder to compensate for the drop in input voltage. I can't imagine that you would actually want to work on the edge like that since you would be on the brink of failure pretty much all the time. A couple of millivolts of ripple on the input and your output will collapse.
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 6th November 2009 at 09:46 PM. | |
| 07v, 11v, increase, temporarily, voltage |
| How to increase the accuracy ? | ahmedragia21 | Micro Controllers | 7 | 19th June 2009 10:31 PM |
| Quick question- Voltage increase when rectified | spitso | General Electronics Chat | 13 | 25th March 2009 06:14 PM |
| increase A while keeping V | duduchier | Electronic Projects Design/Ideas/Reviews | 3 | 13th October 2008 12:16 AM |
| Generator, Voltage/frequency increase | bdsolar | Electronic Projects Design/Ideas/Reviews | 3 | 10th March 2008 06:51 PM |
| want to increase only ampere | mamun2a | General Electronics Chat | 18 | 29th January 2007 07:57 PM |
