Old 6th November 2009, 01:35 PM   #1
Default Replacing 0.56" seven segment display?.
Replacing 0.56" seven segment displays with Kingbright SA23-12SRWA?.
Dear All,
I wish to change the attached circuit to accept the larger Kingbright displays as this circuit only drives smaller 0.56" common anode types, could you please advise me what type of circuit i would need.
( Although the drawing does not actually show it the supply to the displays is currently +5volts and as the SA23 series contains more LEDS per segment i'm assuming the supply volts will need to be higher and i think that might then create a problem form the driving logic. But the 74LS47 used for the segment drive i think should be up to the task )
Many Thanks,
Mark Snape.
Mark Snape is offline
Old 7th November 2009, 07:25 PM   #2
It will be a major problem, as the existing displays are multplexed and the common anode voltage is 5V. The new displays(SA23-12SRWA) need approximately 12V for the common anode voltage. The cathode drive circuits should be fine.
k7elp60 is offline
Old 10th November 2009, 10:47 AM   #3
Many Thanks for taking the time to respond, but isn't that the question
i was asking?.
Cheers,
Mark.
Old 10th November 2009, 11:29 AM   #4
I looked at the datasheets for the new LEDS when you first started this thread and then forgot to compose a reply!
The new 7seg LEDS are pin compatible with the existing ones but will require a higher supply voltage.
The 74ls47 appears to be rated up to 15volts on the open collector drive to the leds, so I think that a 12v LED supply should be OK.
JimB is offline
Old 10th November 2009, 11:55 AM   #5
Many Thanks JimB.
But it's how to translate the +5v o/p of the 'HC154 to drive the SA23-12SRWA
seven segment displays?.
Cheers,
Mark.
Old 10th November 2009, 05:33 PM   #6
Now that comes into the category of "Oh, I never thought of that!".
I think that a 7.5v zener diode between the outputs of the HC154 and the corresponding 2.2k resistors should fix the problem.
Connect the anodes of the zeners to the HC154.
JimB is offline
display, replacing 056, segment
7 segment display "help please" deakin09 Electronic Projects Design/Ideas/Reviews 16 17th April 2009 11:22 PM
replacing lcd panel display with led wsemajb Electronic Projects Design/Ideas/Reviews 4 5th December 2008 12:35 PM
7-Segment RED 6.5" Display sgear1 General Electronics Chat 2 19th February 2008 05:56 AM
LCD display "previous page" problem Alex_rcpilot Micro Controllers 2 31st December 2005 01:19 PM
LCD Text File Display --- "Electronic Book" joe_e General Electronics Chat 22 14th June 2004 03:18 PM
