+ Reply to Thread
Results 1 to 4 of 4
Thread: Thumbwheel switch
  1. #1
    Tuck3rz Newbie
    Join Date
    Oct 2009
    Posts
    26
    Default Thumbwheel switch
    Hi... Can i know what is a Thumbwheel switch for?
    And if so, how do you read the pin configuration
  2. #2
    DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent
    Join Date
    Aug 2003
    Location
    Toronto, Canada
    Posts
    1,308
    It's usually used for scrolling navigation in handheld devices. You can figure out the pins by reading the datasheet or simply using a multimeter to find out what they do when you operate it.
    Mark Higgins
  3. #3
    PatM Newbie
    Join Date
    Apr 2009
    Posts
    95
    BCD Thumbwheel Switch is used to input-set data in digital form, this can be read by digital circuits, uC and uP systems and PLC-SCADA Interfaces.
  4. #4
    alhoop Newbie
    Join Date
    Dec 2008
    Posts
    22
    I use two thumbwheel switches to select stall/service tracks for a model railroad roundhouse and turntable. Here is how to read the two switches using a PicAxe controller with the switch commons tied to + voltage.
    cnt1 = pins & $0F
    cnt1 = pin4 * 10 + cnt1
    cnt1 = pin5 * 20 + cnt1
    If the switch commons are grounded and b0 can be used
    then use the following:
    b0 = pins ^ $3F
    cnt1 = b0 & $0F
    cnt1 = bit4 * 10 + cnt1
    cnt1 = bit5 * 20 + cnt1
    cnt1 is the decimal value of the two switches.
    Al
+ Reply to Thread
  1. Is ADG406 from analog device an electronic switch or mechanical switch?
    By overgift in forum General Electronics Chat
    Latest: 1st April 2009, 01:40 PM
  2. Fan controlled by Air flow switch or Temp Switch
    By sllimbri in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th March 2009, 06:21 PM
  3. Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch
    By blueroomelectronics in forum Micro Controllers
    Latest: 15th May 2008, 10:43 PM
  4. Thumbwheel?
    By computer in forum Datasheet/Parts Requests
    Latest: 19th March 2005, 07:52 PM
  5. Thumbwheel lock project
    By Lizo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th May 2004, 02:38 PM
Tags for this Thread
