Please reference page 9, figure 2 of the following data sheet: http://cds.linear.com/docs/Datasheet/4412fa.pdf Why do they have the P-channel FETs hooked up with the source towards the load? How are these devices working? I am more used to seeing things like Figure 7 for high-side P-channel power switches. Thanks for any help! | |
It's not working backwards. Current flows from Drain to Source. Since it's a p-channel MOSFET, VDG > -VT, and the MOS is in the low power dissapation region. The Sense pin of the IC keeps the FET in that region.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. Last edited by BrownOut; 5th November 2009 at 11:25 PM. | |
Then how does figure 4 work?
Those MOSFET's ARE working backwards LOL! MOSFET's are allowed to work that way, so it's OK.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
Really? Is this because the Vds is essentially zero in these cases?
| | #6 |
VDS is nearly zero, but that's because in a P-channel MOSFET, when VGS< VT and VDG > -VT, a strong inversion layer is formed between the drain and source, which is bidirectional. EDIT: I edited all my conditions for low power dissapation. I get those confused easily.
| | #7 |
The reason the source and drain is connected backward from what you might expect is so the parasitic MOSFET diode (which is connected anode to drain and cathode to source) does not conduct if the wall adapter voltage is significantly higher than the battery voltage, which would perform uncontrolled charging of the battery.
__________________ Carl Curmudgeon Elektroniker | |
| backwards, mosfet, pchannel, working |
| N - channel mosfet H - bridge | cwok | Electronic Projects Design/Ideas/Reviews | 2 | 15th October 2009 04:39 PM |
| Confused with P Channel MOSFET | electronist | General Electronics Chat | 8 | 6th May 2009 10:58 AM |
| 2-amp N-channel MOSFET? | Mike, K8LH | Micro Controllers | 3 | 30th August 2008 05:13 PM |
| P-channel, 60 amp mosfet? | ClydeCrashKop | General Electronics Chat | 17 | 18th June 2006 09:18 PM |
| n channel mosfet | johneppen | General Electronics Chat | 2 | 2nd March 2003 08:42 AM |
