the problem we put the circuit together but when we put my iron moving voltage meter on the board it worked great but when the voltage hit 7volts it made the circuit jump to 15volt this is very confussing to my cousion as im a newbie at electronics what do you think Last edited by mart_1986; 5th November 2009 at 02:17 PM. | |
Have no idea what you are asking. Post a diagram of your circuit.
__________________ Carl Curmudgeon Elektroniker | |
| | #3 | |
the circuit works great with digital and analogue meter reader but when we put my panel mounted iron moving voltage meter on to the circuit and get it to 7volts it makes the whole circuit to jump to 15volts | ||
Where did you connect your meter? R1 for an LM317 is supposed to be 120 ohms or less. It can be up to 240 ohms for the more expensive LM117. With 220 ohms on an LM317 then the output voltage might rise without a load.
| we have flowed the plan so its has the 220ohm at r1 we place the meter at the end of the circuit just before where the exit wires will be to the banana plugs
| | #6 |
| Please talk in English. Maybe you followed (copied) the plan? But the plan is wrong. I do not know why the output voltage doubled when you connected your meter to the output. Maybe your meter was not set to show DC volts and instead was showing DC Amps?
| | #7 | |
0v to 15v meter info Polarised Moving Iron Current and Voltage Meters •Polarised moving-iron meters with robust movements for use on dc and rectified ac only Accuracy ±8% for battery charger applications Operating temperature range –20 to +40°C Snap-in panel fixing Connections 25mm, 1//4 inch spade terminals Last edited by mart_1986; 5th November 2009 at 07:20 PM. | ||
| | #8 |
Are you now a father without being married??
| | #9 |
| | #10 |
Congratulations, daddy-oh! R1 should be 120 ohms or less for an LM317 or use a more expensive LM117 instead with the 220 ohm resistor.
| | #11 |
| lm317t, power, problem, supply |
| power supply problem | doubleM | General Electronics Chat | 11 | 14th October 2009 06:48 PM |
| problem with DC Power supply | alpha_tayyab@yahoo.com | General Electronics Chat | 11 | 9th July 2009 07:11 AM |
| AC/DC power supply problem | hardcore misery | Electronic Projects Design/Ideas/Reviews | 9 | 20th September 2007 02:25 PM |
| Power supply problem | Projectman | Electronic Projects Design/Ideas/Reviews | 10 | 24th July 2007 04:31 PM |
| NIMH Charger LM317T - Problem | Suraj143 | General Electronics Chat | 9 | 10th April 2007 09:40 AM |
