Old 5th November 2009, 02:57 AM   #1
Default Potentiometer
Hey I am building a bubble machine for a project and I can only use 6V max for power. I need to be able to control the speed of one of my motors. Should I use a potentiometer? I have one but I can't get it to work. The motors are 1.5V-3V and being powered 2 AA batteries each. I tried wiring a potentiometer in between the batteries and motor but I cant get it to work properly. The potentiometer is a 100k Ohm Linear Taper Potentiometer, 250VDC .25W. I don't really know what I'm doing with so help would be very appreciated.
cmcimino is offline
Old 5th November 2009, 03:18 AM   #2
You need a much lower value pot. Try a 10Ω or a 100Ω pot. Wire only to wiper and one end.
Mike ML.
MikeMl is offline
Old 5th November 2009, 04:15 AM   #3
OK where can I get that? I got my last one at Radio Shack but I dont think they had any low Ohm pots.
cmcimino is offline
Old 5th November 2009, 04:38 AM   #4
And of course a more efficient way would be PWM.
Problem with a potentiometer is power wasted and heat. If you decide to use a potentiometer, please consider a power resistor in series with the pot and motor of a low enough value as to not deter from the circuit but to current limit the motor. It's a small motor but .25 watts isn't much for your pot and it might get very hot otherwise.
Look into PMW, it is way more efficient and friendlier to your components.
ke5frf is offline
Old 5th November 2009, 04:40 AM   #5
Mouser, digikey, newark, jameco.
Internet mail order.
ke5frf is offline
Old 5th November 2009, 05:12 AM   #6
What is a PWM? I'm new to this stuff so I meet need an explanation for this stuff. Sorry
cmcimino is offline
Old 5th November 2009, 10:20 AM   #7
Goggle for "DC motor speed control" and you will find several tutorials on the subject, including the PWM way.
Creationists have a world of evidence
AllVol is offline
Old 5th November 2009, 06:10 PM   #8
But isn't it an AC motor because I am running it off batteries?
cmcimino is offline
Old 5th November 2009, 06:27 PM   #9
Batteries produce DC.
You were told to Google a DC motor speed controller that will explain Pulse-Width-Modulation (PWM).
audioguru is offline
Old 5th November 2009, 06:29 PM   #10
YIKES
No, no, no, no and noooooooo.
I am so glad, at least, that you are working with low voltages. Please go read up on basic DC/AC electronics!
ke5frf is offline
Old 5th November 2009, 07:00 PM   #11
Haha yea, like I said I'm new this stuff and I need help. I need something cheap to control the speed of a 1.5V-3V motor. Would this work?
25-Ohm 3-Watt Rheostat - RadioShack.com
cmcimino is offline
Old 5th November 2009, 07:22 PM   #12
Should do.
Put it in series.
Use only the middle and one end, as has been said.
Lets us know how it goes.
John
john1 is offline
Old 6th November 2009, 09:41 PM   #13
Yea everything works. I bought a 25 ohm rheostat from radioshack and I am able to control the speed of my motor. Thanks a lot guys!!
cmcimino is offline
Old 7th November 2009, 01:01 AM   #14
Good deal.
I hope you will continue to study in order to understand why it worked... don't be content with this one success, but go to the next level and be able to forsee a result before the attempt.
Added: Also thanks for coming back to let us know your progress. Often, we never know the end result of someone's problem.
AllVol is offline
Old 7th November 2009, 01:07 AM   #15
Frequently when somebody connects a potentiometer in series with a DC motor to control its speed simply reduces its torque so it cannot start running.
potentiometer
potentiometer help Rov General Electronics Chat 4 17th March 2009 10:15 PM
Potentiometer help. BlackOmega General Electronics Chat 3 19th November 2008 01:11 AM
Potentiometer YAN-1 General Electronics Chat 2 24th October 2007 05:18 PM
Do you know this potentiometer? 2PAC Mafia General Electronics Chat 13 19th December 2005 04:14 PM
potentiometer mozikluv General Electronics Chat 3 5th August 2004 03:15 PM
