Old 4th November 2009, 12:11 PM   #1
Default GPS throughput problem
Hi , I plan to use a GPS module at 115200 baud , as this is a high speed GPS receiver . I need this to connect it to atmega16 .
What I am doing is I get long/lat from the GPS and I need to compute approcahing distance from a pre-fed long/lat in the processor at 10Hz/GPS rate.
what I am finding it difficult to figure out is will it be possible to do all this with Atmega16@11.0592MHz XTAL? perfectly or will I face throughput problems .
Regards
Dark
Q: How does Einstein begin a story?
A: Once upon a space-time...
dark is offline
Old 4th November 2009, 12:50 PM   #2
Which GPS receiver are you using. Most are NMEA @ 4800 baud
Bill
Smart Kits build Smart People
Old 4th November 2009, 02:00 PM   #3
Here it is;
http://www.electro-tech-online.com/g....../S1722R.pdf
dark is offline
Old 4th November 2009, 02:11 PM   #4
Broken link.
Bill
Old 4th November 2009, 02:18 PM   #5
Broken link.
Here its
http://www.macrobudapest.hu/WEBSET_D...620/S1722R.pdf
dark is offline
Old 4th November 2009, 02:24 PM   #6
Most GPS receivers will not transmit position strings at more than 1Hz. Yes, you will receive it at 115k but only 1 per second.
The rest of your post I don't understand. Actually, rereading it, it doesn't contain a question.
Pommie is online now
Old 4th November 2009, 02:50 PM   #7
S1722R GPS receiver outputs at 10Hz .
dark is offline
Old 4th November 2009, 02:54 PM   #8
You are correct, it does output at 10Hz.
What is your question?
Old 4th November 2009, 03:19 PM   #9
Please have a look at my first post : I quote it below
"what I am finding it difficult to figure out is will it be possible to do all this with Atmega16@11.0592MHz XTAL? perfectly or will I face throughput problems ."
Aquiring data at that rate and then computing distance every 1/10Hz. Now how easy is this to be done will the computing match the inputdata flow rate.
dark is offline
Old 4th November 2009, 03:51 PM   #10
You will have no problems whatsoever, the Atmega16 will easily manage that.
Old 4th November 2009, 03:59 PM   #11
They may have missed your question because your question had no question mark. (?)
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 4th November 2009, 04:07 PM   #12
Isn't the question mark after the letters XTAL? In both the original post and the quote? What planet are you guys from?
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 4th November 2009, 04:11 PM   #13
I'm from Earth, USA where question marks are usually at the end of sentences, not in the middle.
What's your planet?
Carl
Old 5th November 2009, 06:47 AM   #14
Hi Pommie , and others
Let me explain a little more and see option for adding further components.
I can do this without problem with silabs 8051 high clock variant . Atmega16(5V) I have been ask to do has a limitation with XTAL ,if process goes slow I would be left with no option to replace the entire processor.
Is it ok to further add
1)GLCD128x64
2)Software uart @9600bps(scanning at 1 per second)
4) 4 key switches .
My further question is if I time schedule all process for 20ms will it be ok or will it be a burden for the processor ? or how this should be tackled ?
Regards
dark is offline
Old 5th November 2009, 07:14 AM   #15
I'm not familiar with the AtMega but a quick look at the specs suggests it should be able to handle your requirements. I hope you are a good programmer as I suspect the software uart would need to be implemented using interrupts. If the GLCD is KS0108 based then I have example code in C18 which may be useful.
gps, problem, throughput
Gps mohsinans Electronic Projects Design/Ideas/Reviews 8 18th January 2009 05:51 PM
GPS Tracker Project ( GPS Module + JP Module + LCD Dispaly ) oldspring Electronic Projects Design/Ideas/Reviews 4 8th August 2008 03:07 AM
help with gps athba Electronic Projects Design/Ideas/Reviews 2 3rd April 2007 09:50 PM
GPS hdaroga Electronic Projects Design/Ideas/Reviews 2 20th September 2005 06:17 AM
Magellan GPS 315 flash memory problem Aldo General Electronics Chat 0 31st July 2003 06:37 AM
