May I know how does a Voltage and Current Transducer works and why does is it neccessary to connect it to a dual supplies? How do determine the R1 and Rm of the Transducer if I m were to use a LA25-NP for Current Transducer and LV25-P for Voltage Transducer Thanks and Sorry for the trouble. | |
Anyone is able to help me with my qns? This is de data of the LV25-P ![]() What does HT stands for too? Last edited by Tuck3rz; 5th November 2009 at 03:01 AM. | |
Read the data sheet
__________________ Mike ML. | |
Thanks mike.. I have the datasheet too, just that i'm still unclear about it.
Do you know what "galvanic isolation" is? Read the paragraph starting with the bold title; "Principle of Use" Do you know how to convert a voltage into a current using a resistor? Hint, it has something to do with R1.
__________________ Mike ML. Last edited by MikeMl; 5th November 2009 at 03:57 AM. | |
| | #6 |
Sorry, I dun understand the meaning of it... That means by adding a resistor R1, I m able to measure the voltage? What about Rm? | |
| | #7 |
I'm sorry to be blunt, but why are you using this component? It is designed to solve a specific problem, which is to make an "ungrounded", "floating", or "differential" measurement of current in an ungrounded circuit, while maintaining +- 1000V isolation from the input side to the output side. The device is an active device, meaning it contains opamps, etc which require split supplies to make it work.
| | #8 |
I m designing Two of the LV25-NP and LA25-P transducer to read the voltage and current produced by the generator and also to read the voltage and current inside a lead acid battery. This transducer board will be connected to a Microcontroller board which consist of a ADC and a DS89C450 chip and it is connected to a laptop via a serial port which display the values on the hyperterminal on a laptop. Hope you do understand as my english is not that good. | |
| transducer, voltage or current |
| Need help with Voltage/Current | shaneshane1 | General Electronics Chat | 10 | 3rd December 2007 12:25 AM |
| Current into Voltage? | neel.k | Electronic Projects Design/Ideas/Reviews | 4 | 7th March 2006 04:06 AM |
| voltage and current | VISHOK | General Electronics Chat | 0 | 25th September 2004 09:01 PM |
| Current vs. Voltage | nyeboy2000 | General Electronics Chat | 13 | 28th February 2003 04:49 PM |
| voltage/current | JEBB | General Electronics Chat | 1 | 17th February 2003 09:27 AM |
