Old 3rd November 2009, 03:32 PM   #1
Default How does water affect an inductive loop?
An inductive loop, (well insulated so shorts are not a problem), lies submerged in a pool of water. Apart from problems caused by possible insulation degradation over time, would the pool of water affect any signals sent along the loop - i.e. 'slugging'/attenuation of the signal?
Many thanks
Dixie68 is offline
Old 3rd November 2009, 04:23 PM   #2
It depends upon the relative magnetic permeability of water as compared to air. Since the relative magnetic permeability of air is 1.000,000,37 and water is 0.999992 (a vacuum is 1), the effect of water on the inductive loop will be unmeasureable in most practical applications.
Carl
Curmudgeon Elektroniker
crutschow is online now
Old 3rd November 2009, 07:23 PM   #3
Unless the water is conductive.... Like water in the ground might be.
Mr RB is offline
Old 3rd November 2009, 07:32 PM   #4
According to the OP, the inductor is insulated so that wouldn't be a problem. Question is, why would you want to do that? Heat dissipation? Just put it in a non-conductive bath of oil like a large transformer.
gabeNC is offline
Old 3rd November 2009, 09:55 PM   #5
Mineralized water will affect coil inductance --- it's a crucial issue when it comes to using metal detectors, above ground or under water. Mineralized water affecting the signal depends on signal frequency and emission type.
HiTech is offline
Old 4th November 2009, 08:34 AM   #6
It's not a case of wanting to do it, the loop is part of a rail communications system and the part of the track where it is located floods every now and then.
Aerials on the train pick up signals from the loop inductively.
Dixie68 is offline
Old 4th November 2009, 08:41 AM   #7
... and the frequency of the signal should be no larger than 80khz
Dixie68 is offline
affect, inductive, loop, water
Why does change in voltage affect 555 frequency? MikeBrady General Electronics Chat 25 30th May 2009 12:57 PM
open loop and closed loop control systems waheeda Electronic Projects Design/Ideas/Reviews 2 27th March 2009 05:20 PM
Code Won't Affect PORTA ormo Micro Controllers 17 15th December 2008 10:12 AM
Inductive wire loop sensing jacob.zurasky Electronic Projects Design/Ideas/Reviews 6 30th August 2008 08:59 AM
How will this circuit affect the voltage/current? RaG General Electronics Chat 1 14th April 2005 02:12 AM
