Hi, I am new to this form. I must be the dumbest father on this planet. I have read many, many books and working with electronic breadboards building and learning trying to teach my kid. The thing that is driving me crazy is what do ohms do to volts? See I know about ohms law, and I understand volts is really just pressure, it is current that flows. But what I just don't get is what’s with resistor numbers. I am trying to help my kid and I understand its concept. Here is an easy example. If I have 9 volts and connect 3300k R to an LED, I see that the voltage dropped. But what I don't understand is what does the resistor mean by 3300k? Does it mean that that’s how many electrons it will let through regardless of volts? Do you see what I am trying to get at? I don’t know why my mind is not latching on to the number system of resistor. What exactly does the 3300k do to volts to cause the drop. I know what resistors do but but I don't see what is ohms, is it a unit of measure. Please help Last edited by JunaidKhan; 3rd November 2009 at 07:09 AM. | |
seeing as no one replied as yet, Ohms is a unit of resistance. The resistors are made from different materials and the properties of each material effects the amount of resistance and tolerance. Each resistor has 4 or 5 different coloured stripes on them which tells you the specific ohm value of that resistor and its tolerance.... You can get a multimeter and set it to 'resistance - 20K scale' (ohm symbol Ω) and measure the resistor. It should read 3.3K. Or if you have it on the 2000Ω scale it will read 3300Ω... catching on yet? | |
If we keep to the water analogy of pressure and flow being voltage and current then a resistor is analogous to a restriction in the pipe. The more restricted the pipe the higher the resistance and the bigger pressure will be built up around it. A dripping tap is like a very high value resistor and so the pressure before the tap (in the pipe) is high and after the tap is low and so the pressure difference is high. A fully open tap offers little resistance and so the pressure is pretty much the same before and after the tap. Resistance as you know is measured in ohms but we use the SI units (kilo Meg) in place of the decimal point. So, 2k2 = 2.2k = 2200Ω. 8M9 = 8.9M = 9,800,000Ω. We also use R to indicate no multiplier, 22R = 22Ω and 1R2 = 1.2Ω. In your example with the LED it has to be calculated backward. The LED will have 2V across it (actually not in this case due to a high resistor value) and so the resistor will have 7 and so the current that will flow is I=V/R = 7/3300000 = 0.000002 Amps. I think you may have the wrong resistor value, a normal value for this example would be more like 330Ω. Mike. | |
__________________ Creationists have a world of evidence | |
Google "Ohm's Law", you'll find tons of info. But, in short, if you have 1 volt and your circuit has a resistance of 1 ohm, 1 amp of current will flow through the circuit. Higher voltage increases the current. Higher resistance reduces the current. The formulas are very simple: Amps = Volts / Ohms. Ohms = Volts / Amps. Volts = Amps * Ohms. When you read a schematic, and the resistor has "K" after the value, you would multiply by 1,000. So, a 10k resistor = 10,000 ohms. If it has M after the value, multiply by 1,000,000. So 1M = 1,000,000 ohms. Sometimes a decimal value will use the M or K in place of the decimal point. So, 2.2K = 2K2 = 2,200 ohms. | |
| | #6 |
I will try to explain this in a way that simplifies to the point even a child can understand it. Think of voltage as pressure being applied to something. Say, for instance, when you are moving a bookcase in your home by pushing it across the floor. When you put your shoulder against the bookcase and push, you are applying pressure against it. The floor and the weight of the bookcase are opposing forces to your pressure. The floor creates friction which, combined with the weight of the bookcase, opposes your attempt to move it. This is similar to a resistor in an electronic circuit. The resistor opposes the voltage (pressure) that is pushed against it. The weight of the bookcase can be measured, and so can a resistor...thus the DEGREE to which it opposes the voltage is determined by the measurement in OHMS, just as the degree to which the bookcase resists being moved can be measured or determined by its weight and the smoothness of the floor. Once the resistance of the bookcase is overcome by the pressure exerted upon it by your shoulder, it will begin to slide across the floor. If the floor is smooth and creates little friction, and if the weight of the bookcase isn't particularly heavy, and if you are a fairly strong man, then the bookcase will slide reasonably quickly, with ease. This would be similar to the FLOW or movement of electric current. If the voltage applied is strong and the resistor value is small, the a large current will flow through the circuit. If you are very weak and the weight of the bookcase is very large, then it will be difficult to move it and it will slide slowly. Just as in a circuit, if the voltage applied to a resistor is weak, and the value of the resistor is high, then fewer electrons will be allowed to flow through the circuit. An increase in resistance will have an inversely proportional effect on current flow given that the voltage remains the same. I hope my analogy makes sense. | |
| | #7 | |
Let me break down my thinking so you can see where I get lost. I have a very basic circuit, a 9v connected to a 3.3k resistor connected to an LED. I take my multimeter and take the black wire and rest it on the ‘-’ end of the battery and use my red + wire to check the voltage before the resistor. I know here it will report around 8.70v. My battery is getting a little weak so that’s why it is 8.70. Now after the resistor it shows 3.82v. Ok this is where I get lost. I have not seen any formula in ohms law that shows how the resistor value of 3.3k can be used to see the drop of the volts it will do. Like here when I had 8.70v after 3.3k it dropped to 3.82. How did these numbers happen? So if I had a 6v and used a 3.3k what would be voltage dropped to after 3.3k resistor? This is where my minds is not getting it. Ohms law does not show this, it talks about V,I,R,W. These 2 questions will help me if anyone can anwser these: "What I want to know is how do the numbers on the resistor work if I want to drop a 6v to 2.5v before it enters into the LED.?" "If I had a 6v and used a 3.3k what would be voltage dropped to after 3.3k resistor?" Last edited by JunaidKhan; 3rd November 2009 at 02:31 PM. | ||
| | #8 | |
What you have here is a very poor example for learning "Ohms Law". At the risk of the thread turning into a blood bath, I will state that devices like LEDs, diodes and transistors do not obey Ohms Law. (There has been a lot of heated debate about this in the past!) ![]() Quote:
LEDs have a nearly constant voltage drop arcoss them which varies by only a small amount when the current through them varies. If you set your meter to measure current, in your original circuit you should see that the current is (8.7 - 3.82)/3300 = 1.48mA or maybe a bit less because the meter will add resistance to the circuit, making the current a bit smaller. When you use a 6v battery, the current will be (6 - 3.82)/3300 = 0.66mA. Depending on the LED, it may not be very bright at this low current. JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| | #9 |
Voltage drop occurs when you have 2 resistances in series in the circuit. This is called a voltage divider. For example, say you have a 9 volt battery and you connect 2 1K resistors in series across the battery terminals (they don't have to be 1K, but to make things simple, make them equal). + terminal : 1k resistor : 1k resistor : - terminal If you measure the voltage across the battery terminals, you get 9V (or something close to it). If you measure across one of the 1k resistors, you'll see 1/2 the voltage (4.5 volts). Each resistor is dropping half the voltage, since both resistances are equal. In your example, instead of 2 resistors, you have a LED and the resistor. Diodes (and most other semiconductors) are different from resistors in that they drop a more-or-less constant voltage, drawing as much current as needed to drop that amount of voltage. This is why you need a current-limiting resistor with a LED. So, if your LED has a 2.5V forward voltage, and you're using a 9 volt battery, the LED would drop 2.5V and the resistor would be dropping (9 - 2.5) = 6.5 volts. If you want to limit the current through the LED to 20 mA (0.02 A), use Ohm's Law to calculate the resistor value: R = E/I, Ohms = Volts / Amps, so the resistor would need to be 6.5 / 0.02 = 325 ohms. The closest standard resistor value is 330 ohms, so use that. So, in short, the formula for calculating a LED's series resistor is: R = (Vsource - Vled) / Amps Vsource is your supply voltage (e.g. a 9v battery). Vled is the voltage drop of the LED (get this from the LED's datasheet, will typically be between 2 and 3.5V depending on the LED's color), and Amps is the amount of current you want the LED to draw (keep this below the rated maximum for the LED). Typically this will be in milliamps, so it'll be a number less than 1 (such as 0.02 for 20 mA). Last edited by kpatz; 3rd November 2009 at 02:45 PM. | |
| | #10 |
To understand what you are looking for, in addition to Ohm's law you really should study Kirchoff's laws as well as Thevenin's and Norton's theorems. You should Google those terms and read. You must understand that the LED in your circuit is a resistance in addition to the value of your resistor. Forget the 3.3k resistor and LED for a moment. If you have a resistor that is 6 ohms and an LED that is rated at 3 ohms, (numbers used for simplicity) and a 9 volt battery, then you will read 6 volts across the resistor and 3 volts across the LED when the circuit is energized. The resistor is dropping 66.6 % of the voltage and the LED is dropping the other 33.3 % This is in accordance with Kirchoff's laws. Similarly, with your 3.3k resistor, the resistor is dropping 3.82 volts. lets round that to 4 volts for simplicity. Your supply voltage is 8.7 volts, but lets round that to 9 volts for simplicity. So 9 volt supply minus (-) 4 volt drop = 5 volts. So the other 5 volts is dropping across the LED. So, the resistance of the LED must be more than the resistance of the resistor using Kirchoff's Law. It will be a higher resistance in the same proportions as the voltage drop across it. The resistor is 3.3 Kohms, and with my rounded numbers of 4 and 5 volts for the drops, this means about 44 percent of the voltage is dropping across the resistor. The other 56 % of the voltage is dropping across the LED. This means the resistance of the LED is 12 % higher than the resistance of the resistor. My math may be wrong here, but I estimate the LED value to be about 4.6 Kohms (This using my rounded numbers, not your exact values) | |
| | #11 |
The problem here is that ohms law doesn't apply to LEDs. LEDs will have (generally) 2V across them unless the current is very low as in your case. From your figures the voltage across the resistor is 8.7-3.8 = 4.9V. This is across a 3.3k resistor and so the current is I=V/R = 4.9/3300 = 0.0015A = 1.5mA. I'm guessing that your LED glows very very dimly due to this low current. Change the resistor to a 330 resistor and get a new battery to see a brightly glowing LED. Then measure the voltages and we can do the maths again. Can you see that the thing that defines the voltage across the resistor is the current through it and vice versa. Mike. | |
| | #12 |
| | #13 | |
I think for simplicity's sake we need to avoid specifics like this while someone is trying to wrap their mind around a basic concept such as Ohm's and Kirchoff's laws. It doesn't sound like the OP is at the stage where he or his son is ready for that. I do agree, however, that he should be using pure resistors for demonstrations instead of active components or components with unusual characteristics that undermine the underlying principals. | ||
| | #14 | |
With a LED (or other semiconductor), the device drops a more-or-less fixed voltage, and its internal resistance changes to maintain that fixed voltage. So, instead of R being constant, E is constant. Thus, if an LED is supplied a voltage, it will draw more and more current until the voltage drops to the LED's nominal forward voltage. If the current supply isn't limited, the LED will attempt to draw more current than it can handle and will burn out. The series resistor limits the current, allowing the LED and resistor to act as a voltage divider, allowing the LED to maintain the forward voltage it "likes". To use the water analogy, voltage = water pressure, current = amount of water, and resistance = the thickness of the pipe carrying the water. A semiconductor like an LED would be like a pressure regulating valve. More or less water (current) will flow through the valve to maintain a set pressure (voltage). | ||
| | #15 | |
Mike. | ||
| ohms, volts |
| 9 Volts + 9 Volts = bang ! | RODALCO | Chit-Chat | 6 | 4th May 2008 04:05 AM |
| Reduce 5 volts to 3 volts, suggestions? | prprog | Electronic Projects Design/Ideas/Reviews | 19 | 21st December 2006 07:02 PM |
| 3.7 volts LED with 2 volts | Grimchuck | General Electronics Chat | 9 | 27th April 2003 05:26 PM |
| What are amps, watts, volts and ohms? | john1 | Electronic Projects Design/Ideas/Reviews | 0 | 25th February 2003 02:08 AM |
| What are amps, watts, volts and ohms? | Paprika | General Electronics Chat | 5 | 25th February 2003 02:02 AM |
