Old 3rd November 2009, 03:41 PM   #16
Originally Posted by Pommie View Post
I was thinking we should avoid things like Kirchoff, Thevenin and Norton (from your earlier post).
Why? The question he is asking is about Kirchoff's law.
ke5frf is online now
Old 3rd November 2009, 06:36 PM   #17
Wanted to follow up on this by saying I wasn't trying to be rude when I suggested that discussions about particular voltage/current characteristics of LEDs should be avoided. What I was getting at is that the fellow is obviously trying to understand the fundamentals, and fundamentals are about the "rules and laws". Certain devices "seem" to defy these rules and create exceptions that require detailed explanation. I believe it is helpful to understand the rules first, then tackle all the exceptions. It is, to me, backwards and confusing to have all the exceptions dumped upon you along with the rules and then try to sort it all out at once.
Kirchoff's laws are as fundamental as Ohm's law. Once Ohm's law is understood, more complex series/parallel circuits can be studied using Kirchoff's laws. Then it follows that Thevenin's and Norton's theorems can be studied once Ohm's and Kirchoff's laws are understood. At least this is the way I ALWAYS see it in textbooks, ie the "building block" approach.
Perhaps some of you may learn things by a different method, but that would be the "exception" to the "rule"...(couldn't resist)
Old 4th November 2009, 08:21 AM   #18
the resistor is basicall to limit the current, in your example you can see it limitting, but you cant achive a certain voltage only to be blocked between a ressitor for different voltages.
the definition for Ohm may give you some idea.
the value of a resistor required to establish 1A (you can say in charge flow Q/S) when connected across a 1V source is 1 Ohm.
resistor is to control the current not the voltage.
mbarazeen is offline
Old 4th November 2009, 09:20 AM   #19
Do you expect a kid to understand thevenin's theorem and Kirchoff's law ???
arunb is offline
Old 4th November 2009, 11:23 AM   #20
I think you guys are making it hard on the guy. IMO, he should put the LED aside and understand Ohm's law and how it works in simple circuits containing only resistors. He should also understand how resistors are connected (series and parallel) and how that divides voltage and current.
OP, in your original circuit, if there is no LED, and you only connected the 9v battery to the 3300 ohm resistor, a current of I = V/R = 9/3300 = 0.002727 amps will flow in the circuit(Assuming the battery is exactly 9v). The voltage drop on the resistor will be 9v since it is the only component in the circuit, Or it can also calculated by the same ohm's law. Vr = Ir = .002727*3300 = 9v where I is the total current.
Now, if there is another R connected to the previous 3300 ohm resistor in series like this:
http://mysite.mweb.co.za/residents/v...h/r_series.jpg
Then you will have to first calculate the total resistance which is basically the sum of the two resistors(in this case) before you can calculate the total current and assuming the second resistor is 1000 ohms then I = V/R = 9/(3300+1000) = .00209 amps
In this case the voltage will be divided and it will be
Vr1 = I*r1 = .00209 * 3300 = 6.9 v
Vr2 = I*r2 = .00209 * 1000 = 2.9 v
If this same second R is connected like this
http://image.tutorvista.com/content/...d-battery.jpeg
which means it is connected in parallel then the total R is calculated differently and the law for that is this
http://www.radio-electronics.com/inf...n_parallel.gif
which when we apply, it will give a value of 767.44 ohms which will give a current of V/Rt = 9/767.44 = .011727 amps. This is the total current, and in this case the current is the one that is going to be divided between the two resistors. Some of it will go to the first R and some will go to the second R in a way so that both R's have the same voltage.
==> Ir1 = V/r1 = 9 / 3300 = .002727 amps
and Ir2 = V/r2 = 9 / 1000 = 0.009 amps
This is how it works. You should understand it first with resistors, then go to the more complicated stuff.
sram is offline
Old 4th November 2009, 12:01 PM   #21
Kirchoff's Law, certainly.
If he can't, we might as well quit commenting on this thread because that is exactly what we are trying to explain. What we call it is irrelevant. It might as well be called Bugs Bunny's Law.
And I would certainly expect him to understand Kirchoff's Law and how it applies to a very simple, two or three resistor series circuit before I would a circuit combining components that behave in mathematically different ways.
So my question to you is, do you really expect a child to understand the behavior of PN a junction in a light emitting diode and how it behaves in a series circuit BEFORE he understands how two resistors behave in a series circuit?
Old 4th November 2009, 12:03 PM   #22
Thank you.
Old 4th November 2009, 12:14 PM   #23
Originally Posted by JunaidKhan View Post
Here is an easy example. If I have 9 volts and connect 3300k R to an LED, I see that the voltage dropped. But what I don't understand is what does the resistor mean by 3300k? Does it mean that that’s how many electrons it will let through regardless of volts?
To further emphasize my point, I would say that is actually NOT an easy example. You should start by understanding circuits with only resisters first. The LED is basically a diode:
Diode - Wikipedia, the free encyclopedia
And it can get a bit confusing with a diode. I wouldn't explain ohm's law to a starter with a diode involved !
sram is offline
Old 4th November 2009, 12:26 PM   #24
Wow, this thread deteriorated rapidly. Why can't we keep to simple ohms law and get him understanding that before going on to more complex stuff.
Looks to me like everyone wants to boast how much they know rather than help the original poster.
Just stick to ohms law and let the guy learn.
Pommie is offline
Old 4th November 2009, 02:05 PM   #25
I totally agree, keep it simple.
Ohm's Law is simple.
Actually, Kirchoff's law is even more simple, i.e. it is simple addition, kindergarten stuff (1+1=2)
Stick to those two principals first. Glad we agree on something.
Edit: I apologize, I do not mean to come across as combative. I just VERY STRONGLY feel that learning electronics is a building block process and should be approached as such to avoid confusion....especially with a child.
ohms, volts
9 Volts + 9 Volts = bang ! RODALCO Chit-Chat 6 4th May 2008 04:05 AM
Reduce 5 volts to 3 volts, suggestions? prprog Electronic Projects Design/Ideas/Reviews 19 21st December 2006 07:02 PM
3.7 volts LED with 2 volts Grimchuck General Electronics Chat 9 27th April 2003 05:26 PM
What are amps, watts, volts and ohms? john1 Electronic Projects Design/Ideas/Reviews 0 25th February 2003 02:08 AM
What are amps, watts, volts and ohms? Paprika General Electronics Chat 5 25th February 2003 02:02 AM
